Connection Status: Unreachable Address
Posted: Sat Feb 21, 2015 4:59 pm
In the process of finishing the setup of my Reef Angel. I have run through the wizard and uploaded my code to the device. I have opened the necessary port on my router (2000), created a DMZ on my modem/router and can access my reef angel externally from my network. I have set DDNS on no-ip which is working.
However, I want to take advantage of the portal on here and setup a forum banner for my controller. I cannot seem to get the portal to receive data from my controller. It says my forum name and below it it says Connection Status: Unreachable Address.
Here is my code. Ideally I could get the DDNS provided by reef angel setup and get my controller updating the portal. Anything I am missing on why this isn't working would be much appreciated!
Port Assignment:
Port1 - Light1
Port2 - Light2
Port3 - Vortech MP10
Port4 - Heater
Port5 - Skimmer
Port6 - Reactor
Port7 - ATO
Port8 - Return
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port4Bit;
InternalMemory.OverheatTemp_write( 840 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,10,0,21,0 );
ReefAngel.StandardLights( Port2,0,0,19,0 );
ReefAngel.StandardHeater( Port4,780,790 );
ReefAngel.Portal( "nyknicks4412" );
ReefAngel.DDNS( "controller" );
