Longer data graphs than 7 days?
Related to the Portal
PostPosted: Sat May 09, 2015 4:28 pm
Is there a way to see data in the portal for longer periods of time than 7 days? I would like to see my ph over the course of, say, a month instead of just a week. Is that doable?
PostPosted: Sat May 09, 2015 8:21 pm
Check out www.reeftronics.net
PostPosted: Tue May 12, 2015 3:52 pm
Looks like a great service. Being kind of a noob though, I'm not quite clear what they're asking for in the application. Is it just the DNS info to link to the portal?
PostPosted: Wed May 13, 2015 5:40 am
No, they'll need to query your controller, so you need to have some dynamic DNS. If you don't know how to set that up, there's an option to configure it right on the RA. I'm not up to speed on the process though. I'm sure others can chime in with it if you need help.
PostPosted: Thu May 14, 2015 6:54 am
Got it all figured out. Just needed all the same info that I used to connect the UApp to my controller. Thanks!
Return to Portal
