Portal Web Chart function not working? Client issue as well
Posted: Wed Oct 07, 2015 7:07 am
Portal Dash Board is working fine, and shows no error status, but, if I open the Web Chart tab, I am unable to use the Zoom feature, deselect parameters, or adjust the date range. It has been this way since I moved 2 months ago.
Another issue I am having is with the ReefAngel Client V3.0. The listener will not connect. This only started happening within the last week or so. I tried reinstalling it, and it will show connected for about 30 seconds, then fails.
Because of these 2 issues, the only charting I can use/view is on my iPhone using the app. Everything is working as it should on the app, with no connection issues.
Is there anything I need to do to correct either of these issues?
Thanks much
Thanks much
