Portal Not updating
Related to the Portal
PostPosted: Tue Jan 05, 2016 4:33 am
Hi All
My Portal for some reason is not updating. Please have a look at my code.
I am puzzled. it communicates but just not updates the graphs and the parameters??
// Autogenerated file by RAGen (v1.2.2.171), (04/28/2012 21:19)
// RA_042812_2119.ino
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define RemoveAllLights
#define SaveRelayState
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 6
#define CUSTOM_MAIN
#define COLORS_PDE
#define ENABLE_ATO_LOGGING
#define FONT_8x8
#define NUMBERS_8x16
//#include <RA_PWM.h>
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Water Change";
prog_char menu1_label[] PROGMEM = "ATO Clear";
prog_char menu2_label[] PROGMEM = "Overheat Clear";
prog_char menu3_label[] PROGMEM = "Dosing Additives";
prog_char menu5_label[] PROGMEM = "Date / Time";
prog_char menu6_label[] PROGMEM = "Version";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label };
void MenuEntry1()
void MenuEntry2()
ReefAngel.ATOClear();
void MenuEntry3()
ReefAngel.OverheatClear();
void MenuEntry4()
ReefAngel.FeedingModeStart();
ReefAngel.DisplayMenuEntry("Feeding and Dosing");
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
//ReefAngel.LCD.DrawDate(6, 123);
//pingSerial();
// Display Temp Text
ReefAngel.LCD.DrawText(0,255,12,77,"Temp");
// Display the T1 temp value 10,22
char text[7];
ReefAngel.LCD.Clear(255, 0, 22, 50, 36);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 10, 88, text, Num8x16);
// Display pH Text
ReefAngel.LCD.DrawText(0,255,100,77,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 90, 22, 98, 36);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 90, 88, text, Num8x16);
ConvertNumToString(text, ReefAngel.Params.ORP, 1);
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,13,40,"ORP");
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 13, 50, text, Num8x16);
// byte TempRelay = ReefAngel.Relay.RelayData;
// TempRelay &= ReefAngel.Relay.RelayMaskOff;
// TempRelay |= ReefAngel.Relay.RelayMaskOn;
// ReefAngel.LCD.DrawOutletBox(13, 108, TempRelay);
// ReefAngel.LCD.DrawGraph(5, 24);
// pingSerial();
// Initialize the custom menu
InternalMemory.ATOTimeout_write(32767);
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit ;
ReefAngel.WaterChangePorts = Port4Bit | Port8Bit ;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port6Bit | Port7Bit;
// ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port4);
////// Place addition initialization code below here
ReefAngel.PHMin=538;// 540=PH7.0 529 ph7 346
ReefAngel.PHMax= 821;// 980=PH10.0 ph4 53
// if(hour()==1 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==2 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==3 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==4 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==5 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==6 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==7 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==8 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==9 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==10 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==11 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==12 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==13 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==14 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==15 && minute()==55 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==16 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==17 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==18 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==19 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==20 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==21 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==22 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==23 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==00 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 0, " "); //Top Banner
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 2, " Reef Angel "); //Top Banner
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 10, " Willie's 2M Reef "); //Top Banner
//ReefAngel.StandardATO(Port1,100000); // Standard ATO
ReefAngel.SingleATO(true,Port1,32767,0);
ReefAngel.Relay.DelayedOn(Port5, 1);
ReefAngel.StandardHeater(Port7,258,260); // Heater
ReefAngel.StandardHeater(Port6,258,260); // Heater
ReefAngel.Portal("williet");
if ( ReefAngel.Params.PH >= 780) ReefAngel.Relay.On(Port2);
if ( ReefAngel.Params.PH <= 780 ) ReefAngel.Relay.Off(Port2);
PostPosted: Tue Jan 05, 2016 6:47 am
Did you setup a key in the portal settings?
PostPosted: Tue Jan 05, 2016 11:17 pm
lnevo wrote:Did you setup a key in the portal settings?
Hi
I have no key setup.
PostPosted: Wed Jan 06, 2016 7:08 am
when you say it communicates but does not update the graphs or parameters, what do you mean?
How do you know it communicates? if it is communicating then the parameters should be updated. Otherwise, your communication is probably not working.
This probably sounds silly but is your wifi module connected to your network? Can you communicate with the RA using one of the apps? Can you bring up the internal webserver on the controller?
Just trying to get some more information because the code looks ok and the portal line looks correct for no security key.
PostPosted: Tue Jan 12, 2016 6:10 am
binder wrote:when you say it communicates but does not update the graphs or parameters, what do you mean?
Hi Yes
I can access it. I even control the reefangel from the App on my phone. it just does not update the portal.
Did it last in September 2015 ?
Return to Portal
