Portal Not updating
Posted: Tue Jan 05, 2016 4:33 am
Hi All
My Portal for some reason is not updating. Please have a look at my code.
I am puzzled. it communicates but just not updates the graphs and the parameters??
// Autogenerated file by RAGen (v1.2.2.171), (04/28/2012 21:19)
// RA_042812_2119.ino
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define RemoveAllLights
#define SaveRelayState
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 6
#define CUSTOM_MAIN
#define COLORS_PDE
#define ENABLE_ATO_LOGGING
#define FONT_8x8
#define NUMBERS_8x16
//#include <RA_PWM.h>
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Water Change";
prog_char menu1_label[] PROGMEM = "ATO Clear";
prog_char menu2_label[] PROGMEM = "Overheat Clear";
prog_char menu3_label[] PROGMEM = "Dosing Additives";
prog_char menu4_label[] PROGMEM = "PH Calibration";
prog_char menu5_label[] PROGMEM = "Date / Time";
prog_char menu6_label[] PROGMEM = "Version";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label };
void MenuEntry1()
void MenuEntry2()
ReefAngel.ATOClear();
void MenuEntry3()
ReefAngel.OverheatClear();
void MenuEntry4()
ReefAngel.FeedingModeStart();
ReefAngel.DisplayMenuEntry("Feeding and Dosing");
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
//ReefAngel.LCD.DrawDate(6, 123);
//pingSerial();
// Display Temp Text
ReefAngel.LCD.DrawText(0,255,12,77,"Temp");
// Display the T1 temp value 10,22
char text[7];
ReefAngel.LCD.Clear(255, 0, 22, 50, 36);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 10, 88, text, Num8x16);
// Display pH Text
ReefAngel.LCD.DrawText(0,255,100,77,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 90, 22, 98, 36);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 90, 88, text, Num8x16);
ConvertNumToString(text, ReefAngel.Params.ORP, 1);
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,13,40,"ORP");
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 13, 50, text, Num8x16);
// byte TempRelay = ReefAngel.Relay.RelayData;
// TempRelay &= ReefAngel.Relay.RelayMaskOff;
// TempRelay |= ReefAngel.Relay.RelayMaskOn;
// ReefAngel.LCD.DrawOutletBox(13, 108, TempRelay);
// ReefAngel.LCD.DrawGraph(5, 24);
// pingSerial();
// Initialize the custom menu
InternalMemory.ATOTimeout_write(32767);
ReefAngel.SetTemperatureUnit(1); // set to Celsius Temperature
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit ;
ReefAngel.WaterChangePorts = Port4Bit | Port8Bit ;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port6Bit | Port7Bit;
// ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port4);
////// Place addition initialization code below here
ReefAngel.PHMin=538;// 540=PH7.0 529 ph7 346
ReefAngel.PHMax= 821;// 980=PH10.0 ph4 53
// if(hour()==1 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==2 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==3 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==4 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==5 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==6 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==7 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==8 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==9 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==10 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==11 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==12 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==13 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==14 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==15 && minute()==55 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==16 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==17 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==18 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==19 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==20 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==21 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==22 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
// if(hour()==23 && minute()==00 && second()==0) ReefAngel.Relay.On(Port2);
// if(hour()==00 && minute()==00 && second()==0) ReefAngel.Relay.Off(Port2);
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 0, " "); //Top Banner
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 2, " Reef Angel "); //Top Banner
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 10, " Willie's 2M Reef "); //Top Banner
//ReefAngel.StandardATO(Port1,100000); // Standard ATO
ReefAngel.SingleATO(true,Port1,32767,0);
ReefAngel.Relay.DelayedOn(Port5, 1);
ReefAngel.StandardHeater(Port7,258,260); // Heater
ReefAngel.StandardHeater(Port6,258,260); // Heater
ReefAngel.Portal("williet");
if ( ReefAngel.Params.PH >= 780) ReefAngel.Relay.On(Port2);
if ( ReefAngel.Params.PH <= 780 ) ReefAngel.Relay.Off(Port2);
#define VersionMenu
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x8
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
//pingSerial();
char text[7];
// Display pH Text
// Display pH Value
// pingSerial();
