Wifi Working, Need help setting up Portal and external acces
Related to the Portal
PostPosted: Tue Aug 23, 2016 2:10 am
Hi All,
Just got a RA Plus and super stoked with it so far.
i have managed to configure the WIFI module and so far have that working.
(only if connected to my local network)
i also seem to have got the portal up and running (dumb luck) - but only in one direction. ie info is showing but i cannot control the RA.
I have a TP-Link Router with DDNS and Port Forwarding ( i am a noob here so please be patient!)
when i look at the DDNS i only get 2 options: No-IP and dyndns
can someone help walk me through this?
i'd like to be able to control the tank remotely and obviously view detail in it remotely
Kind Regards
Furbz
PostPosted: Wed Aug 24, 2016 5:53 am
OK, not my area of expertise, but I believe you should leave that blank. Make sure you have the DDNS line in your code. See here: viewtopic.php?f=20&t=4754
HOWEVER, I don't think this affects portal operation. This still sounds like a forwarding problem. You will need to assign a static IP to the RA Wifi, then make sure port 2000 is forwarded to that address. I'm not familiar with TP-Link so I won't be much help there.
Return to Portal
