Portal and U-app fine tuning help
Related to the Portal
PostPosted: Wed Aug 31, 2016 10:27 am
I am trying to use the portal and app. I have checked my code and it looks like I have everything in there that is needed. When I access the portal it works but the dashboard is incorrect. It is only showing one relay box it should show three. When I first enter portal it is always on a date in Sept 2013 as last data, but I have looked at it since 2013 . If I cycle a relay on the dashboard it will then refresh and show correct data? This only happens on my computer not my Iphone if I access the portal from my phone It is correct dashboard and data is refreshed.
Second issue is when I add the ipaddress that the portal is using to the App it does not work?
Am I correct in using that ip? Also I do have comcast:
Wifi setup went well no issues. green light flashes every sec. no blue light flashing,good right?
I also Went into comcast router and turned on port forwarding :2000 for the ip of the wifi attachment.
Any help on this would be great.Thank you
Here is my Code:
ReefAngel.AddPARExpansion(); // PAR Expanion Module
ReefAngel.FeedingModePortsE[0] = Port6Bit | Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port5Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port5Bit;
ReefAngel.DDNS("tank" );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Box3_Port1 );
ReefAngel.Relay.On( Box3_Port2 );
ReefAngel.Relay.On( Box3_Port3 );
ReefAngel.Relay.On( Box3_Port4 );
ReefAngel.Relay.On( Box3_Port5 );
ReefAngel.Relay.On( Box3_Port6 );
ReefAngel.Relay.On( Box3_Port7 );
ReefAngel.Relay.On( Box3_Port8 );
ReefAngel.StandardLights( Port2,10,0,19,30 );
ReefAngel.StandardFan(Box1_Port7,806,786);
ReefAngel.StandardFan2(Box1_Port8,900,856);
ReefAngel.StandardLights( Port3,10,0,19,30 );
ReefAngel.StandardLights( Port4,10,0,19,30 );
ReefAngel.SingleATO( true,Port8,60,0 );
// ReefAngel.StandardHeater( Box1_Port5,627,810 );
ReefAngel.PWM.SetChannel( 0, PWMSlope(10,0,19,30,15,100,60,15) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(10,0,19,30,15,100,60,15) );
ReefAngel.PWM.SetChannel( 2, MoonPhase() );
ReefAngel.PWM.SetChannel( 3, PWMSlope(10,0,19,30,15,100,60,15) );
ReefAngel.PWM.SetChannel( 4, PWMSlope(10,0,19,30,15,100,60,15) );
ReefAngel.Portal( "bmhair03" );
PostPosted: Wed Aug 31, 2016 10:29 am
Update..
OK I have the portal running fine dashboard correct etc .But still cant get app to work. Any advice there?Thanks
PostPosted: Wed Aug 31, 2016 10:50 am
Started to just click stuff in App. Now it's working. Did the same as portal cycled a relay and it started working perfectly.
So thank anyway but I'm ok. For now !
Return to Portal
