Portal issues?
Re: Portal issues?
Sure. How do I do that?
Sent from my LG-V410 using Tapatalk
Re: Portal issues?
For me issue was solved after I've run the macro that was mentioned in this post. Seems that it was only needed to change server address
Re: Portal issues?
Use tera term and connect to the serial port at 57600 baud.
Then type $$$ to enter command mode.
It should respond with CMD
Type get e and post what you see on the screen.
Re: Portal issues?
I too had the same problem. Last update was 23rd December 2016. Ran the macro once and now its updating correctly.
Dr Davaraj
Dr Davaraj
Re: Portal issues?
I can't do it today, buy should be able to tomorrow.
Re: Portal issues?
Here it is
get e
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on RN-131
SSID=WiFly-GSX-32
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.1.8:2000
NM=255.255.255.0
GW=192.168.1.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=XXXXXXX
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=XXXXXXXXXX
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
get e
SSID=WiFly-GSX-32
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.1.8:2000
NM=255.255.255.0
GW=192.168.1.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=XXXXXXX
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
Re: Portal issues?
It is still the old server.
Either you have the old macro or the macro didn't run correctly.
Give it a try again. Make sure to download the macro from the website. Do not use any one that you may have downloaded a few months back.
Re: Portal issues?
Looks like it is working now. Thanks!
Re: Portal issues?
So is this a matter of changing the reef angel server IP? I don't use the wifi attachment, ive got the ethernet module. Only reason I came on here today is because this morning I noticed that my MH were not on at the right time. Checked the app, and both my MH and my heaters were set to off manually. This worried me so came here and checked portal only to find out last update was 24/12.
Re: Portal issues?
Yes, just change the server ip address in the code for your ethernet module
Re: Portal issues?
still getting blue light of death
This is after running Macro in TeraTerm
ERR: ?-Cmd
<4.00> get e
wifly-GSX Ver 4.00.1, Apr 19 2013 11:48:31 on RN-131
Beacon=102
Reboot=0
IF=DOWN
DHCP=ON
IP=192.168.1.3:2006
NM=255.255.255.0
GW=192.168.1.1
HOST=104.36.18.155:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=testing2
Chan=0
ExtAnt=0
Join=1
Auth=WPA1
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=a01b02c03d
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
Re: Portal issues?
Had to run WIFI utility and all is well now
Re: Portal issues?
Yeah I struggle with following directions some times - hahahahah
Re: Portal issues?
Ahhh, back to the same problem, no longer getting access to the portal. Looks like it's been going on since March 24.
Re: Portal issues?
here is the tera term dump
SSID=WiFly-GSX-32
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.1.8:2000
NM=255.255.255.0
GW=192.168.1.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=XXXXXX
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=XXXXXXXX
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
Re: Portal issues?
No, just tried to reload wifi macro, but same thing.
Re: Portal issues?
Everything looks ok with the wifi attachment.
Let's get another log.
Connect the USB-TTL cable to RA.
Open Arduino
Make sure you have the correct serial port selected
Go to Tools->Serial Monitor
Make sure you have 57600 baud. If not, you will need to change to 57600 and close serial monitor and open again
Wait 5 minutes for RA to send data
Send whatever you get on the serial monitor window
Open Arduino
Re: Portal issues?
GET /status/submitp.aspx?t1=793&t2=797&t3=0&ph=802&id=ucez&em=0&em1=0&rem=1&bid=1&key=&ddns=Reef&af=0&sf=0&atohigh=1&atolow=1&r=117&ron=0&roff=255&r1=235&ron1=0&roff1=255
GET /status/submitp.aspx?t1=791&t2=798&t3=0&ph=801&id=ucez&em=0&em1=0&rem=1&bid=1&key=&ddns=Reef&af=0&sf=0&atohigh=1&atolow=1&r=117&ron=0&roff=255&r1=235&ron1=0&roff1=255
Re: Portal issues?
Could it be the cable between RA and wifi attachment?
RA seems to be sending data and wifi attachment is connected to the wifi network with the correct ip address.
Everything looks ok.
Re: Portal issues?
I can access the RA directly, just not through the portal. Maybe something has gone screwy with my router? Heading out of town today so will have to investigate when I get back...
Re: Portal issues?
Am I wrong that if the cable was bad it wouldn't connect to the wifi network and send data that way?
Re: Portal issues?
There are 4 wires for the module to communicate.
GND and VCC which provide power. If any of those wires fail, the module wouldn't even power up when plugged into RA, but it would when connected to USB-TTL cable.
So, we know these are not the problem.
The other 2 are TX and RX, which transmit and receive data respectively.
If RX is bad, the module would be able to connect to your wifi network, but RA cannot send data to wifi module because the RX wire would be bad and data would never reach the wifi module.
That's why I asked to check the log for RA.
This is what RA sends to the module and the module simply relays the same message to the portal.
If TX was bad, it would still receive data from RA and relay to the portal. So, you would get data in the portal, but when you initiated a call from the portal or the phone app, the wifi module wouldn't be able to send the data back to RA. In this case, portal would receive data but you wouldn't be able to use any of the apps.
But you mentioned that you can indeed connect to the module and control it using the app when using the internal ip address, which makes it very weird, because it confirms that the cable is not bad. Both TX and RX need to be good in order to have communication back and forth with the app.
So, can you confirm that the app works and communicates with the system using your internal ip address?
Re: Portal issues?
I'll check tomorrow when back in town, but the app was working fine. I use it almost daily to feed.
Re: Portal issues?
Ok, now this is getting a little bizarre. I can connect via the IPad app, but not via the android app.
Re: Portal issues?
Just checked the portal, now it's connected - getting data and taking commands...I didn't do anything except unplug/replug the wifi attachment, which wasn't on (no lights) when I got home. Could the wifi attachment or cable be going bad?
Re: Portal issues?
Android app not connection through portal either, IP address same.
