Portal issues?
Related to the Portal
PostPosted: Wed Dec 28, 2016 9:16 am
Paul_Velasco wrote:Just so you know you are not insane. Have not changed code in months. Live data showing but no recent data to Portal. Stopped collecting data on 12/23 no updates since that date.
FWIW, I'm seeing the same thing. Live data in the android/iOS apps and portal but no historical data since 12/23 in any of the three. I have tried rebooting the controller but it made no difference. I'm remote right now so there isn't much else I can try.
- Bill
PostPosted: Wed Dec 28, 2016 9:26 am
Have you guys updated the wifi attachment with the tera term macro yet?
I want to make sure this is the problem.
PostPosted: Wed Dec 28, 2016 10:27 am
Months ago when I could not even connect? It stopped same day for me 12/23.
Reboot last night nothing.
PostPosted: Wed Dec 28, 2016 10:39 am
Months ago doesnt work. I'd like you to update again to make sure you are pointing to the correct server
PostPosted: Wed Dec 28, 2016 11:20 am
There is no way to update the WiFi settings from 200 miles away, is there? e.g. with an SSH connection instead of over the serial cable?
Unless there is, I cannot try that until next week. Sorry...
- Bill
PostPosted: Wed Dec 28, 2016 11:23 am
There is with telnet, but you have to be super fast and I'm not so sure if you will be able to do it.
I've never tried before.
PostPosted: Wed Dec 28, 2016 11:44 am
Ah... I haven't looked carefully at the ttl file yet but I can easily pipe the guts of it into telnet (or probably netcat) so typing speed is irrelevant. Or by speed do you mean getting all the commands in before a connection reset happens?
Anyway, my internet connection is a bit dodgy where I am right now and there is other stuff going on so I don't want to try it today. But tomorrow I should have both time and a solid connection so I'll look into it then.
PostPosted: Wed Dec 28, 2016 12:02 pm
The setting that is on your module is "set c i 3"
Which means if the connection is idle (no incoming characters) for 3 seconds, it will close it.
So, if you can make it without typing, you may in good shape.
PostPosted: Sat Dec 31, 2016 1:53 pm
Ran the macro to fix the issue with portal history not working, now my wifi adapter won't even connect...
When I change the SSID and my wifi SSID has a space in between it, how do I word it in the macro file? I'm assuming that could be the issue?
PostPosted: Sat Dec 31, 2016 4:21 pm
Use $ instead of space.
Return to Portal
