Page 6 of 9
Re: Portal issues?
PostPosted: Mon Jan 16, 2017 11:42 am
Yes, just change the server ip address in the code for your ethernet module
Re: Portal issues?
PostPosted: Tue Jan 31, 2017 6:55 pm
by Paul_Velasco
still getting blue light of death
This is after running Macro in TeraTerm
ERR: ?-Cmd
<4.00> get e
wifly-GSX Ver 4.00.1, Apr 19 2013 11:48:31 on RN-131
Beacon=102
Reboot=0
IF=DOWN
DHCP=ON
IP=192.168.1.3:2006
NM=255.255.255.0
GW=192.168.1.1
HOST=104.36.18.155:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=testing2
Chan=0
ExtAnt=0
Join=1
Auth=WPA1
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=a01b02c03d
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
Re: Portal issues?
PostPosted: Tue Jan 31, 2017 7:11 pm
by Paul_Velasco
Had to run WIFI utility and all is well now
Re: Portal issues?
PostPosted: Tue Jan 31, 2017 11:38 pm
You never edited the file with your ssid and password.
Re: Portal issues?
PostPosted: Wed Feb 01, 2017 3:28 pm
by Paul_Velasco
Yeah I struggle with following directions some times - hahahahah
Re: Portal issues?
PostPosted: Mon Apr 10, 2017 3:04 pm
by ucez
Ahhh, back to the same problem, no longer getting access to the portal. Looks like it's been going on since March 24.
Re: Portal issues?
PostPosted: Mon Apr 10, 2017 3:20 pm
by ucez
here is the tera term dump
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on RN-131
SSID=WiFly-GSX-32
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.1.8:2000
NM=255.255.255.0
GW=192.168.1.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=XXXXXX
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=XXXXXXXX
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
Re: Portal issues?
PostPosted: Mon Apr 10, 2017 3:26 pm
Have you uploaded any code around that time?
Re: Portal issues?
PostPosted: Mon Apr 10, 2017 3:31 pm
by ucez
No, just tried to reload wifi macro, but same thing.
Re: Portal issues?
PostPosted: Mon Apr 10, 2017 7:00 pm
Everything looks ok with the wifi attachment.
Let's get another log.
Connect the USB-TTL cable to RA.
Open Arduino
Make sure you have the correct serial port selected
Go to Tools->Serial Monitor
Make sure you have 57600 baud. If not, you will need to change to 57600 and close serial monitor and open again
Wait 5 minutes for RA to send data
Send whatever you get on the serial monitor window
