WiFi cloud attachment to portal
Related to the Portal
PostPosted: Thu Jan 12, 2017 8:31 pm
Will the new cloud wifi also be able to connect to the portal?
Also the iPhone/iPad app does not connect to my cloud wifi..
-James-
PostPosted: Thu Jan 12, 2017 9:28 pm
It can, but the portal will require you to use ip/port and thus you need to setup port forwarding on your router.
PostPosted: Fri Jan 13, 2017 9:31 am
Ok, once I get the attachment module to work with my RA+, I will try that.
-James-
PostPosted: Sat Jan 14, 2017 9:24 pm
It works on the portal. Woohoo.....
-James-
Return to Portal
