Loggin activity
Related to the Portal
PostPosted: Mon May 15, 2017 2:59 pm
I created a google sheet to download and log the RA status. I did his because I wanted to have a longer log than 7 days (I am collecting the data only every hour now), and have my own dashboard with charts to see how things are going.
This is working well. However, I have some questions on what each of the metrics in /status mean. Is there a place where it goes over each of them? Also, where would relay activity show up?
Let me know if anyone is interested, happy to share.
Lucho
PostPosted: Mon May 15, 2017 7:50 pm
Nice :)
It's an XML file with all the parameters for everything we can log.
I don't think we created a document.
Start with the source code:
https://github.com/reefangel/Libraries/ ... i.cpp#L223
If you still unsure of any of them, let us know.
PostPosted: Wed May 17, 2017 6:21 am
Thanks Roberto. I think I managed to get most of them. I only have a few missing (EM, EM1, REM, R1-8, RON1-8, ROFF1-8, and SF).
The question may be answered with the above, but where can I see relay status? I have 2 relay expansions.
thanks,
Lucho
PostPosted: Wed May 17, 2017 11:16 am
EM and EM1 are for expansion modules enabled.
SF and AF are for status flags and Alert flags.
REM is for which relay expansion module you have enabled.
R1-8 are the expansion relay boxes without the override flags.
RON1-8 are the expansion relay boxes override flag for always on flags.
ROFF1-8 are the expansion relay boxes override flag for always off flags.
In the Global.h, you will find the bits.
// EM Bits
#ifdef PWMEXPANSION
   #define PWMEbit      1
#else
   #define PWMEbit      0
#endif  // PWMEXPANSION
#ifdef RFEXPANSION
   #define RFEbit      2
#else
   #define RFEbit      0
#endif  // RFEXPANSION
#ifdef AI_LED
   #define AIbit      4
#else
   #define AIbit      0
#endif  // AI_LED
#ifdef SALINITYEXPANSION
   #define Salbit      8
#else
   #define Salbit      0
#endif  // SALINITYEXPANSION
#ifdef ORPEXPANSION
   #define ORPbit      16
#else
   #define ORPbit      0
#endif  // ORPEXPANSION
#ifdef IOEXPANSION
   #define IObit      32
#else
   #define IObit      0
#endif  // IOEXPANSION
#ifdef PHEXPANSION
   #define PHbit      64
#else
   #define PHbit      0
#endif  // PHEXPANSION
#if defined WATERLEVELEXPANSION || defined MULTIWATERLEVELEXPANSION
   #define WLbit      128
#else
   #define WLbit      0
#endif  // WATERLEVELEXPANSION || MULTIWATERLEVELEXPANSION
// EM1 Bits
#ifdef HUMIDITYEXPANSION
   #define HUMbit      1
#else
   #define HUMbit      0
#endif  // HUMIDITYEXPANSION
#ifdef DCPUMPCONTROL
   #define DCPumpbit   2
#else
   #define DCPumpbit   0
#endif  // DCPUMPCONTROL
#ifdef LEAKDETECTOREXPANSION
   #define Leakbit      4
#else
   #define Leakbit      0
#endif  // LEAKDETECTOREXPANSION
#ifdef PAREXPANSION
   #define PARbit      8
#else
   #define PARbit      0
#endif  // PAREXPANSION
#ifdef SIXTEENCHPWMEXPANSION
   #define SCPWMbit      16
#else
   #define SCPWMbit      0
#endif  // SIXTEENCHPWMEXPANSION
// Alert Flags bits
#define ATOTimeOutFlag   0
#define OverheatFlag      1
#define BusLockFlag      2
#define LeakFlag          3
// Status Flag Bits
#define LightsOnFlag      0
#define FeedingFlag      1
#define WaterChangeFlag   2
PostPosted: Fri May 19, 2017 7:35 am
Thanks for the quick reply.
I am clearly beyond my expertise.
Are the bits pieces you quoted above a way to understand what the number means? E.g., a 3 in AF means Leak flag is activated?
The other is in the relays. If i understand well, there are 3 status output per relay box (R, RON, and ROFF), with a number result for each. How do I translate that to knowing the status of each outlet within the relay box?
Thanks a lot!
rimai wrote:EM and EM1 are for expansion modules enabled.
// EM Bits
#ifdef PWMEXPANSION
   #define PWMEbit      1
#else
   #define PWMEbit      0
#ifdef RFEXPANSION
   #define RFEbit      2
#else
   #define RFEbit      0
#ifdef AI_LED
   #define AIbit      4
#else
   #define AIbit      0
#endif  // AI_LED
   #define Salbit      8
#else
   #define Salbit      0
#ifdef ORPEXPANSION
   #define ORPbit      16
#else
   #define ORPbit      0
#ifdef IOEXPANSION
   #define IObit      32
#else
   #define IObit      0
#ifdef PHEXPANSION
   #define PHbit      64
#else
   #define PHbit      0
   #define WLbit      128
#else
   #define WLbit      0
// EM1 Bits
   #define HUMbit      1
#else
   #define HUMbit      0
   #define DCPumpbit   2
#else
   #define DCPumpbit   0
   #define Leakbit      4
#else
   #define Leakbit      0
#ifdef PAREXPANSION
   #define PARbit      8
#else
   #define PARbit      0
   #define SCPWMbit      16
#else
   #define SCPWMbit      0
// Alert Flags bits
#define LeakFlag          3
// Status Flag Bits
PostPosted: Fri May 19, 2017 9:10 am
You will need to learn a little about binary numbers.
Google "binary number".
Here is one hit: https://www.mathsisfun.com/binary-number-system.html
Basically, the decimal number that the controller gives is a decimal representation of an 8bit number.
So, let's say you get 9 on R. The binary representation of the decimal 9 number is: 00001001
So, port 1 and port 4 would be on.
RON and ROFF are the override masks for On and Off.
You need to bitwise AND and OR the masks.
The formula is ( R || RON ) && ROFF
You need to bitwise OR RON and then bitwise AND ROFF. This will give you what the relay ports will be like after the override masks are applied.
PostPosted: Fri May 19, 2017 11:06 am
Got it. Thanks, I now decoded the relays piece (I am familiar with binary). Is this also the thinking behind the AF and SF?
PostPosted: Fri May 19, 2017 11:43 am
Yes.
PostPosted: Thu May 10, 2018 5:16 am
Lucho, would you be willing to share this google sheet?
Return to Portal
