Loggin activity
Posted: Mon May 15, 2017 2:59 pm
by lucho
I created a google sheet to download and log the RA status. I did his because I wanted to have a longer log than 7 days (I am collecting the data only every hour now), and have my own dashboard with charts to see how things are going.
This is working well. However, I have some questions on what each of the metrics in /status mean. Is there a place where it goes over each of them? Also, where would relay activity show up?
Let me know if anyone is interested, happy to share.
Lucho
Re: Loggin activity
Posted: Mon May 15, 2017 7:50 pm
Nice
It's an XML file with all the parameters for everything we can log.
I don't think we created a document.
Start with the source code:
https://github.com/reefangel/Libraries/ ... i.cpp#L223
If you still unsure of any of them, let us know.
Re: Loggin activity
Posted: Wed May 17, 2017 6:21 am
by lucho
Thanks Roberto. I think I managed to get most of them. I only have a few missing (EM, EM1, REM, R1-8, RON1-8, ROFF1-8, and SF).
The question may be answered with the above, but where can I see relay status? I have 2 relay expansions.
thanks,
Lucho
Re: Loggin activity
Posted: Wed May 17, 2017 11:16 am
EM and EM1 are for expansion modules enabled.
SF and AF are for status flags and Alert flags.
REM is for which relay expansion module you have enabled.
R1-8 are the expansion relay boxes without the override flags.
RON1-8 are the expansion relay boxes override flag for always on flags.
ROFF1-8 are the expansion relay boxes override flag for always off flags.
In the Global.h, you will find the bits.
// EM Bits
#ifdef PWMEXPANSION
#define PWMEbit 1
#else
#define PWMEbit 0
#endif // PWMEXPANSION
#ifdef RFEXPANSION
#define RFEbit 2
#else
#define RFEbit 0
#endif // RFEXPANSION
#ifdef AI_LED
#define AIbit 4
#else
#define AIbit 0
#endif // AI_LED
#ifdef SALINITYEXPANSION
#define Salbit 8
#else
#define Salbit 0
#endif // SALINITYEXPANSION
#ifdef ORPEXPANSION
#define ORPbit 16
#else
#define ORPbit 0
#endif // ORPEXPANSION
#ifdef IOEXPANSION
#define IObit 32
#else
#define IObit 0
#endif // IOEXPANSION
#ifdef PHEXPANSION
#define PHbit 64
#else
#define PHbit 0
#endif // PHEXPANSION
#if defined WATERLEVELEXPANSION || defined MULTIWATERLEVELEXPANSION
#define WLbit 128
#else
#define WLbit 0
#endif // WATERLEVELEXPANSION || MULTIWATERLEVELEXPANSION
// EM1 Bits
#ifdef HUMIDITYEXPANSION
#define HUMbit 1
#else
#define HUMbit 0
#endif // HUMIDITYEXPANSION
#ifdef DCPUMPCONTROL
#define DCPumpbit 2
#else
#define DCPumpbit 0
#endif // DCPUMPCONTROL
#ifdef LEAKDETECTOREXPANSION
#define Leakbit 4
#else
#define Leakbit 0
#endif // LEAKDETECTOREXPANSION
#ifdef PAREXPANSION
#define PARbit 8
#else
#define PARbit 0
#endif // PAREXPANSION
#ifdef SIXTEENCHPWMEXPANSION
#define SCPWMbit 16
#else
#define SCPWMbit 0
#endif // SIXTEENCHPWMEXPANSION
// Alert Flags bits
#define ATOTimeOutFlag 0
#define OverheatFlag 1
#define BusLockFlag 2
#define LeakFlag 3
// Status Flag Bits
#define LightsOnFlag 0
#define FeedingFlag 1
#define WaterChangeFlag 2
Re: Loggin activity
Posted: Fri May 19, 2017 7:35 am
by lucho
Thanks for the quick reply.
I am clearly beyond my expertise.
Are the bits pieces you quoted above a way to understand what the number means? E.g., a 3 in AF means Leak flag is activated?
The other is in the relays. If i understand well, there are 3 status output per relay box (R, RON, and ROFF), with a number result for each. How do I translate that to knowing the status of each outlet within the relay box?
Thanks a lot!
rimai wrote:EM and EM1 are for expansion modules enabled.
// EM Bits
#ifdef PWMEXPANSION
#define PWMEbit 1
#else
#define PWMEbit 0
#ifdef RFEXPANSION
#define RFEbit 2
#else
#define RFEbit 0
#ifdef AI_LED
#define AIbit 4
#else
#define AIbit 0
#endif // AI_LED
#define Salbit 8
#else
#define Salbit 0
#ifdef ORPEXPANSION
#define ORPbit 16
#else
#define ORPbit 0
#ifdef IOEXPANSION
#define IObit 32
#else
#define IObit 0
#ifdef PHEXPANSION
#define PHbit 64
#else
#define PHbit 0
#define WLbit 128
#else
#define WLbit 0
// EM1 Bits
#define HUMbit 1
#else
#define HUMbit 0
#define DCPumpbit 2
#else
#define DCPumpbit 0
#define Leakbit 4
#else
#define Leakbit 0
#ifdef PAREXPANSION
#define PARbit 8
#else
#define PARbit 0
#define SCPWMbit 16
#else
#define SCPWMbit 0
// Alert Flags bits
#define LeakFlag 3
// Status Flag Bits
Re: Loggin activity
Posted: Fri May 19, 2017 9:10 am
You will need to learn a little about binary numbers.
Google "binary number".
Here is one hit:
https://www.mathsisfun.com/binary-number-system.html
Basically, the decimal number that the controller gives is a decimal representation of an 8bit number.
So, let's say you get 9 on R. The binary representation of the decimal 9 number is: 00001001
So, port 1 and port 4 would be on.
RON and ROFF are the override masks for On and Off.
You need to bitwise AND and OR the masks.
The formula is ( R || RON ) && ROFF
You need to bitwise OR RON and then bitwise AND ROFF. This will give you what the relay ports will be like after the override masks are applied.
Re: Loggin activity
Posted: Fri May 19, 2017 11:06 am
by lucho
Got it. Thanks, I now decoded the relays piece (I am familiar with binary). Is this also the thinking behind the AF and SF?
Re: Loggin activity
Posted: Fri May 19, 2017 11:43 am
Yes.
Re: Loggin activity
Posted: Thu May 10, 2018 5:16 am
by dlplunkett44
Lucho, would you be willing to share this google sheet?
