Setting values for Portal email alerts
Related to the Portal
PostPosted: Mon Jun 12, 2017 10:29 pm
What value do you use for "on" / "off" when creating Portal email alerts? I'm using my float switches for ATO failsafes (set higher and lower than my Water Level Expansion settings). I want to know when these are activated but not sure what value to put when creating the alert.
PostPosted: Tue Jun 13, 2017 3:25 am
typically 0 is for off and 1 is for on.
I'm pretty sure that's how the controller responds. I haven't looked at it for a while, so I'm not 100% positive but I'm pretty sure. if I'm wrong, someone else will chime in to correct me.
PostPosted: Tue Jun 13, 2017 4:43 pm
Thanks! So I should be safe with >=1 for on, correct?
PostPosted: Tue Jun 13, 2017 6:48 pm
jcjrogers wrote:Thanks! So I should be safe with >=1 for on, correct?
yup, you should be.
And I just looked at my code and confirmed that 0 is OFF and 1 is ON.
PostPosted: Tue Jun 13, 2017 6:58 pm
yup, you should be.
Return to Portal
