Setting values for Portal email alerts
Posted: Mon Jun 12, 2017 10:29 pm
by jcjrogers
What value do you use for "on" / "off" when creating Portal email alerts? I'm using my float switches for ATO failsafes (set higher and lower than my Water Level Expansion settings). I want to know when these are activated but not sure what value to put when creating the alert.
Re: Setting values for Portal email alerts
Posted: Tue Jun 13, 2017 3:25 am
typically 0 is for off and 1 is for on.
I'm pretty sure that's how the controller responds. I haven't looked at it for a while, so I'm not 100% positive but I'm pretty sure. if I'm wrong, someone else will chime in to correct me.
Posted: Tue Jun 13, 2017 4:43 pm
by jcjrogers
Thanks! So I should be safe with >=1 for on, correct?
Posted: Tue Jun 13, 2017 6:48 pm
jcjrogers wrote:Thanks! So I should be safe with >=1 for on, correct?
yup, you should be.
And I just looked at my code and confirmed that 0 is OFF and 1 is ON.
Posted: Tue Jun 13, 2017 6:58 pm
by jcjrogers
binder wrote:jcjrogers wrote:Thanks! So I should be safe with >=1 for on, correct?
yup, you should be.
