Page 1 of 5
Unreachable Address in portal
PostPosted: Tue Aug 29, 2017 3:06 pm
by Irieivan
When i type in the ip address and port into my browser, i receive current data, but when i go to graphs, i get no data error.
I get no information when i am logged in to the portal, "unreachable address."
I have downloaded the iphone app but no data there.
Am i missing something basic?
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperature
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit | Port4Bit | Port5Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port4Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port7Bit | Port8Bit;
    ReefAngel.PHControl( Port2,818,822 );
    ReefAngel.StandardLights( Port4,9,0,19,0 );
    ReefAngel.Relay.DelayedOn( Port5,1 );
    ReefAngel.WaterLevelATO( Port6,225,44,46 );
    ReefAngel.StandardHeater( Port7,255,265 );
    ReefAngel.Relay.DelayedOn( Port8,1 );
    ReefAngel.Relay.DelayedOn( Box1_Port4,1 );
    ReefAngel.Portal( "irieivan" );
Re: Unreachable Address in portal
PostPosted: Tue Aug 29, 2017 4:12 pm
Looking at your other post, I can see that the firmware of the wifi attachment module needs to be updated.
Follow instructions here: viewtopic.php?f=3&t=4601
PostPosted: Tue Aug 29, 2017 4:49 pm
by Irieivan
When I Open Tera I need to choose between TCP/IP (lots of options here I know nothing about) or serial. Which do I choose?
And where must wifi be plugged in to while I do this?
PostPosted: Tue Aug 29, 2017 5:02 pm
by Irieivan
This is what I get in the tera window:
ã!¤É¶þÉþ?|h¦ ´ÍÎÎ>®¦???¤Û´~td=?ÞJ
Îî
PostPosted: Tue Aug 29, 2017 5:10 pm
by Irieivan
and now this, it keeps saying start Wifly module configuration.= on a tera popup and no connection on the reef angel wifi attachment when I try and set it up. Nothing makes me feel as stupid as as this...it really feels like its two steps forward and three backwards:
CMD
factory RESET
Set Factory Defaults
<4.41> reboot
*Reboot*CMD
set ftp address 198.175.253.161
AOK
<4.41> save
Storing in config
<4.41> set wlan ssid IvanVoda
AOK
<4.41> set wlan pass 1
AOK
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
<4.41> set dns name http://www.reefangel.com
AOK
<4.41> set i h 104.36.18.155
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
<4.41> set u b 57600
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*CMD
factory RESET
<4.41> reboot
*Reboot*CMD
AOK
<4.41> save
Storing in config
AOK
AOK
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
AOK
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*CMD
factory RESET
<4.41> reboot
PostPosted: Tue Aug 29, 2017 5:40 pm
by Irieivan
I close the wifi setup window, connect and I get the wifi set up, but when do I run the macro. If I first run the macro, and then go to wifi setup, I cannot get anything connected:
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM3
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM3
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM3
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 86328 3 wifly-GSX-400
< 4 74920 3 web_app-GSX-106
< 7 46632 3 wps_app-GSX-131
< 9 66240 3 eap_app-GSX-101
< 11 37282 0 web_config.html
< 21 512 0 link.html
< 24 1052 10 config
< 25 1052 10 user
< 26 88548 3 wifly-GSX-441-r1057
< 27 88548 3 NO NAME
< 130 Free, Boot=26, Backup=2
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s IvanVoda
< set w s IvanVoda
< AOK
< <4.41>
> set w p 1
< set w p 1
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=IvanVoda
< Chan=5
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=OPEN
< DHCP=OK,renew=64796
< Boot=2267
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< IP=192.168.0.101:2000
< NM=255.255.255.0
< GW=192.168.0.1
< HOST=104.36.18.155:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Found router R216
Port 2000 is now being forwarded to 192.168.0.101
** ERROR: Connecting to COM3
** Error inside Serial.<init>()
PostPosted: Tue Aug 29, 2017 5:47 pm
It looks like everything is already all set.
It picked up an ip address: IP=192.168.0.101:2000
And the host has been updated: HOST=104.36.18.155:80
Just plug it into RA and wait 5 minutes.
The controller sends data to the portal every 5 minutes.
PostPosted: Tue Aug 29, 2017 5:51 pm
by Irieivan
Thanks, that was hell
PostPosted: Tue Aug 29, 2017 5:57 pm
by Irieivan
How do I get the app working on my phone now
PostPosted: Tue Aug 29, 2017 6:21 pm
You need to setup port forwarding on your router.
If you don't want to setup port forwarding, you can get the new cloud wifi attachment that uses a cloud server to communicate and then there is no setup on your end.
All routers block incoming connections by default as it thinks it is an intruder. You must specify that you want to allow traffic on port 2000 to enter and forward it to your wifi attachment ip address.
