Portal, data logging, app issues
Related to the Portal
PostPosted: Sun Nov 05, 2017 5:55 pm
Can you post your code?
PostPosted: Sun Nov 05, 2017 8:14 pm
rimai wrote:Can you post your code?
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <PAR.h>
#include <ReefAngel.h>
  ReefAngel.AddStandardMenu(); // Let's use 2014 Screen
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit;
    ReefAngel.StandardHeater( Port2 );
    ReefAngel.ActinicLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.Relay.DelayedOn( Port5 );
    ReefAngel.Relay.DelayedOn( Port7 );
    ReefAngel.Relay.Set( Port8, !ReefAngel.Relay.Status( Port4 ) );
    ReefAngel.Portal ( "reefoffillory" );
I changed the part about the standard menu [as advance as my arduino/coding knowledge goes] and I changed the last part about the portal [that you said to do earlier]
I got this coding after using the Wizard
PostPosted: Sun Nov 05, 2017 10:16 pm
Well, you are using internal memory code and we can't see the settings you are using.
But, I just reread the post and there is no such thing as delayed start after feeding in the wizard.
For lights, if you use hard coded settings, you can pick the time to start and stop.
PostPosted: Mon Nov 06, 2017 11:52 am
rimai wrote:Well, you are using internal memory code and we can't see the settings you are using.
I must have misunderstood the wording from the wizard, I thought it said under 'delayed start' that it's the amount of time that outlets are shut off after entering feeding and/or waterchange mode.
Is it better to use internal memory code or another type? I'm guessing this is in relation to the second screen of the wizard? I don't really need to be able to adjust the settings in the portal - I don't mind hooking my laptop up to the RA in order to change settings
PostPosted: Mon Nov 06, 2017 1:13 pm
Yes, you better off using hard coded settings.
PostPosted: Tue Nov 07, 2017 12:55 pm
delayed start is the amount of time the outlet remains OFF after one of the following: exiting water change mode, feeding mode and controller start up
so if you set port1 to have a 1 minute delayed start, it won’t turn on until 1 minute after you have 1 of the 3 previously mentioned scenarios.
this is useful if you have a powerhead that is out of the water during water changes and it takes your return pump a minute to get the water level back up to normal. so you wouldn’t want that powerhead on and running out of the water immediately after your water change.
PostPosted: Wed Nov 08, 2017 2:19 pm
binder wrote:delayed start is the amount of time the outlet remains OFF after one of the following: exiting water change mode, feeding mode and controller start up
That was how I intended to use it, I wanted my skimmer to stay off for 15 minutes, and my ATO to stay off for 20 minutes (how I set it up in the wizard) but it's not working, going to try again sometime this week
PostPosted: Thu Nov 09, 2017 10:30 am
Unless someone changed the libraries, the delayedstart is only applicable to power on delays.
PostPosted: Thu Nov 30, 2017 8:23 am
rimai wrote:Unless someone changed the libraries, the delayedstart is only applicable to power on delays.
I tried searching the forum for information, but couldn't find anything. Am I able to download the data in the portal history to a form which is able to be manipulated such as a comma delimited/excel etc. file?
I'd like to be able to log my data for more than 3 days at a time, even if that means I have to download data every 3 days and compile it into a spreadsheet myself.
Is there already the capability to do this? I only see the option on the webchart to export image files
PostPosted: Thu Nov 30, 2017 10:14 am
Sure. You can get a json formatted file.
status/jsonp.aspx?id=reefoffillory&filter=t1
Return to Portal
