Portal Issues
Related to the Portal
PostPosted: Sat Nov 25, 2017 11:09 am
Need some help,
I am able to see all my data on my app but on the portal it says that it is an unreachable address.
Both of the IP's are the same and port forwarding is open according to "www.yougetsignal"
However I cannot connect to the portal or to the app outside of wifi and the graphs have no data to display.
PostPosted: Sat Nov 25, 2017 11:17 am
Is it RA+ or RA*?
If RA+, when did you purchase the wifi attachment?
PostPosted: Sat Nov 25, 2017 11:25 am
de
PostPosted: Sat Nov 25, 2017 11:40 am
rimai wrote:Is it RA+ or RA*?
Its the +, I purchased it used about 2 years ago. I got the portal working, I did it by using my actual IP address and the 2000 port, not the one for the Wifi attachment?
Still no chart data though
PostPosted: Sat Nov 25, 2017 2:00 pm
You need to update the WiFi attachment.
viewtopic.php?f=3&t=4601
PostPosted: Tue Dec 05, 2017 6:11 pm
rimai wrote:You need to update the WiFi attachment.
Alright, how would I go about doing it on my macbook? Also the Wifi attachment is working fine, just don't have graph data, does that still mean I need to update it?
PostPosted: Tue Dec 05, 2017 9:18 pm
Yes, you do.
On Mac, you would have to manually update it using coolterm or another type of serial monitor app.
PostPosted: Wed Dec 06, 2017 4:25 pm
rimai wrote:Yes, you do.
How do I tell if it updated successfully? I downloaded Coolterm, followed the steps, modified and pasted the code, it "sent" the code (didnt say it had errors) I plugged it into my RA, it still connected but I still don't have access to graph information.
PostPosted: Wed Dec 06, 2017 4:30 pm
Can you post the results of "get e" command?
PostPosted: Wed Dec 06, 2017 9:16 pm
rimai wrote:Can you post the results of "get e" command?
67 65 74 20 65 0D 0A
Next
Return to Portal
