Portal Issues
Posted: Sat Nov 25, 2017 11:09 am
by CalebC
Need some help,
I am able to see all my data on my app but on the portal it says that it is an unreachable address.
Both of the IP's are the same and port forwarding is open according to "
www.yougetsignal"
However I cannot connect to the portal or to the app outside of wifi and the graphs have no data to display.
Re: Portal Issues
Posted: Sat Nov 25, 2017 11:17 am
Is it RA+ or RA*?
If RA+, when did you purchase the wifi attachment?
Re: Portal Issues
Posted: Sat Nov 25, 2017 11:25 am
by CalebC
de
Re: Portal Issues
Posted: Sat Nov 25, 2017 11:40 am
by CalebC
rimai wrote:Is it RA+ or RA*?
Its the +, I purchased it used about 2 years ago. I got the portal working, I did it by using my actual IP address and the 2000 port, not the one for the Wifi attachment?
Still no chart data though
Re: Portal Issues
Posted: Sat Nov 25, 2017 2:00 pm
Re: Portal Issues
Posted: Tue Dec 05, 2017 6:11 pm
by CalebC
Alright, how would I go about doing it on my macbook? Also the Wifi attachment is working fine, just don't have graph data, does that still mean I need to update it?
Re: Portal Issues
Posted: Tue Dec 05, 2017 9:18 pm
Yes, you do.
On Mac, you would have to manually update it using coolterm or another type of serial monitor app.
Re: Portal Issues
Posted: Wed Dec 06, 2017 4:25 pm
by CalebC
rimai wrote:Yes, you do.
How do I tell if it updated successfully? I downloaded Coolterm, followed the steps, modified and pasted the code, it "sent" the code (didnt say it had errors) I plugged it into my RA, it still connected but I still don't have access to graph information.
Re: Portal Issues
Posted: Wed Dec 06, 2017 4:30 pm
Can you post the results of "get e" command?
Re: Portal Issues
Posted: Wed Dec 06, 2017 9:16 pm
by CalebC
rimai wrote:Can you post the results of "get e" command?
67 65 74 20 65 0D 0A
Re: Portal Issues
Posted: Wed Dec 06, 2017 11:40 pm
That's not correct.
Make sure to connect at 57600 baud rate
When you are connected, type "$$$". It will return with a prompt. type "get e"
Re: Portal Issues
Posted: Thu Dec 07, 2017 2:44 pm
by CalebC
rimai wrote:That's not correct.
Re: Portal Issues
Posted: Thu Dec 07, 2017 4:07 pm
It did not update your host entry.
It should show
So, connect again and send command "set i h 104.36.18.155"
Then send "save" and send "reboot"
Just to make sure it updated, grab the "get e" again and see if it updated.
If it did, you are all good.
