Unreachable address
Related to the Portal
PostPosted: Sat Dec 09, 2017 8:42 am
I also have another set of questions on the portal and uapp functionality. When the controller is not hung, I can access the portal and everything seems to be updating. For uapp, I can only seem to access the control functions, when I am remote. Is there a limitation that would prevent those when I am on the local network? I must be missing something. Thanks for your assistance.
PostPosted: Sat Dec 09, 2017 4:43 pm
Controller hung again. Flashing red light
PostPosted: Sat Dec 09, 2017 7:26 pm
It seems you are getting bus locks.
What kind of pulsing are you referring to?
Is it for koralia type pumps?
I would suggest avoiding that and see if this makes any difference.
PostPosted: Sun Dec 10, 2017 7:57 am
Yeah. I am turning a Tunze powerhead on and off on a 10 second interval. 10 sec on and 10 sec off. Just flipping the outlet on the expansion module. I will try to turn that off to see if it stops hanging. Interesting lock because when it is in the hang State, the pump is no longer cycling and the graphing of parameters no longer works but I am still able to reach the controller with uapp and reboot the controller. Question, I have several features, e.g. water level, ph, temp that are defined in the code but not yet hooked up. Could the absence of those devices cause a bus hang?
Previous
Return to Portal
