Portal, Uapp, History, etc.
Posted: Thu Dec 14, 2017 8:00 pm
by paperdesk
So, I'm trying to figure out a few things.
1. The portal doesn't work for me at all anymore (it's been a while actually).
2. The RA android app and the Uapp work fine, except that the uapp will not display history.
3. I really miss the ability the portal had to see relay history too.
4. Did something change with the portal, or could it be on my end?
Ted
Re: Portal, Uapp, History, etc.
Posted: Thu Dec 14, 2017 10:55 pm
Posted: Fri Dec 15, 2017 10:11 am
by paperdesk
I feel like I've done this in the past, but maybe it needs it again. I'll try this and see what happens.
Ted
Posted: Fri Jan 05, 2018 12:33 am
by paperdesk
I updated the wifi attachment, didn't help. What is supposed to display in Tera Term to show it has completed the update successfully?
Posted: Fri Jan 05, 2018 9:56 am
An entire log on stuff is suppose to show.
Can you post the log?
Posted: Mon Jan 08, 2018 12:12 am
by paperdesk
So maybe my Wifi Attachment is now softbricked. I did a bunch of reading in the RA forums, and found a post (
http://forum.reefangel.com/viewtopic.ph ... 1&start=50) where you said the SSID cannot have a space in it, and to replace it with a "$" I did that, and ran the macro, and the wifi attachment started going solid yellow and red, and occasionally flashing blue. Every time it flashed blue it shows a handshake fail in Tera Term.
I fussed with it for a while, and couldn't get anywhere. I thought my USB cable may be bad, so I plugged in a second wifi attachment from another tank. I updated the attachment a couple different times without the "$" symbol, and everything worked fine, so I then replaced the SSID space with an "$" and not it has the same problem as the first. Is there anything I can do now? I guess I've substantiated that the "$" symbol is not a good replacement for a space in the SSID.
Posted: Mon Jan 08, 2018 5:22 pm
$ is the correct way.
Not sure what happened.
Can you send the log?
Posted: Mon Jan 08, 2018 8:01 pm
by paperdesk
I can't seem to pull up a log.
Posted: Mon Jan 08, 2018 8:02 pm
Copy and paste what you get on tera term
Posted: Mon Jan 08, 2018 9:47 pm
by paperdesk
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
EAP-TLS Client APP version 1.00 10/11/12
*FAIL*, handshake
EAP TRY #2
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
*FAIL*, handshake
EAP TRY #2
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
*FAIL*, handshake
EAP TRY #2
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
Posted: Mon Jan 08, 2018 9:50 pm
by paperdesk
Here is the .ttl file info:
x=0
while x<>121
messagebox 'Start WiFly module configuration' 'Webscan Config Program'
;this macro all sent with 5 msec character delay
timeout=10
send '$$$'
wait 'CMD'
sendln 'factory RESET'
wait 'Set Factory Defaults'
sendln 'reboot'
wait '*READY*'
; Begin user settings
send '$$$'
wait 'CMD'
sendln 'set ftp address 198.175.253.161'
wait'AOK'
sendln 'save'
wait 'config'
sendln 'set wlan ssid YD$Staff'
wait 'AOK'
sendln 'set wlan pass AS44:Efdsse'
wait 'AOK'
sendln 'set option deviceid ReefAngelWifi'
wait 'AOK'
sendln 'set w j 1'
wait 'AOK'
sendln 'set c c 0'
wait 'AOK'
sendln 'set c r 0'
wait 'AOK'
sendln 'set c o 0'
wait 'AOK'
sendln 'set i d 1'
wait 'AOK'
sendln 'set c i 3'
wait 'AOK'
sendln 'set dns name
www.reefangel.com'
wait 'AOK'
sendln 'set i h 104.36.18.155'
wait 'AOK'
sendln 'set i r 80'
wait 'AOK'
sendln 'set i f 0x06'
wait 'AOK'
sendln 'set s t 0x10'
wait 'AOK'
sendln 'set u m 2'
wait 'AOK'
sendln 'set i p 2'
wait 'AOK'
sendln 'set u b 57600'
wait 'AOK'
sendln 'set s p 0'
wait 'AOK'
sendln 'set c s 1420'
wait 'AOK'
sendln 'save'
wait 'config'
sendln 'save user'
wait 'user'
sendln'reboot'
;inputbox 'Configure another module (y/n)' 'WiFly Config Program'
; convert inputstr to ASCII int value
; str2code x inputstr
endwhile
Posted: Mon Jan 08, 2018 11:38 pm
Can you send the log of what happens when you hit ok on the button to configure the module?
Posted: Tue Jan 09, 2018 8:06 am
by paperdesk
CMD
factory RESET
<4.41> reboot
*Reboot*EAP-TLS Client APP version 1.00 10/11/12
*FAIL*, handshake
EAP TRY #2
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
*FAIL*, handshake
EAP TRY #2
*FAIL*, handshake
EAP TRY #3
Posted: Tue Jan 09, 2018 8:12 am
by paperdesk
Posted: Tue Jan 09, 2018 9:08 am
Not sure what happened there.
When was this unit bought?
If you want to send it back to be checked out, send me a PM for a RMA number.
Posted: Tue Jan 09, 2018 9:19 am
by paperdesk
Could it possibly be the cable? Both adapters are several years old. Both units were working prior to this. Same code and same result. I really don't know what to make of it. I'll PM you, but unless we figure out what's going on I would expect the same thing to happen with a new unit.
