Connection failure
Related to the Portal
PostPosted: Fri Jan 26, 2018 3:04 am
Hi
I have problem with connection to portal.
I have done the installation and port forwarding but still its not working?
PostPosted: Fri Jan 26, 2018 5:03 am
Have you updated the wifi attachment?
http://forum.reefangel.com/viewtopic.php?f=3&t=4601
PostPosted: Fri Jan 26, 2018 10:01 am
I dont know. Buyed it used. How do i update it? Its the old wifi
PostPosted: Fri Jan 26, 2018 10:45 am
Follow the instructions here http://forum.reefangel.com/viewtopic.php?f=3&t=4601
PostPosted: Fri Jan 26, 2018 1:35 pm
ok thanks but i dont understand. What is ssid och passphrase?
PostPosted: Thu Feb 08, 2018 9:33 am
I have trried to do this in the link but still dont work. Its impossible to connect to the portal. And have done port foreward in my router. One strange thing is that when i put in my ip on the portal setting is that it changes to another number as soon as i log off and log in it has changed again?
PostPosted: Thu Feb 08, 2018 10:06 am
Go here:
https://www.yougetsignal.com/tools/open-ports/
Check for port 2000.
Does the ip address shown in that page matches the one in the portal?
PostPosted: Thu Feb 08, 2018 10:35 am
yes it does. Does it mean that the port is open? What should i do to make the connection work?
PostPosted: Thu Feb 08, 2018 10:37 am
When you check port 2000, does it show open?
PostPosted: Thu Feb 08, 2018 10:44 am
No it says closed for both ip number. But i have the port open Image
Return to Portal
