Setting up RA* for Portal
Posted: Wed Jul 11, 2018 9:02 pm
by ReefingHavoc
Is there something I have to do to set the Portal up to recognize my RA*? It was previously set up for RA+ and is showing unreachable address as I disconnected the Wifi attachment from the RA+. My RA* is showing Cloud Connection: Connected and I've been able to upload code remotely through the wizard.
Thanks ~
Re: Setting up RA* for Portal
Posted: Wed Jul 11, 2018 9:41 pm
Use the uapp instead of the portal:
http://forum.reefangel.com/uapp
Just make sure that when when creating a profile, you just set the cloud username and password and leave the ip and port blank.
Posted: Thu Jul 12, 2018 7:04 pm
by ReefingHavoc
Thanks Roberto!
Posted: Sun Jul 15, 2018 1:37 pm
by ReefingHavoc
I'm not sure where to go next. My uapp shows connected to the cloud through a browser, but I'm not getting any data - Temp; Relay Status, etc.
I'm also trying to use the iPhone uapp and it the cloud server is disconnected. I've tried updating the password multiple times and the UserID and PW is blank.
My RA* unit is showing a successful connection to the cloud. Thoughts?
Posted: Sun Jul 15, 2018 2:34 pm
Uapp for iPhone is not updated. Use the web browser version on Safari and it should work the same way.
If you browse
http://ipaddress:2000/r99 what do you get?
Get the ip address on the status page of the controller.
Posted: Sun Jul 15, 2018 3:52 pm
by ReefingHavoc
rimai wrote:Uapp for iPhone is not updated. Use the web browser version on Safari and it should work the same way.
If you browse
I'm getting this from my desktop:
"ipaddress’s server IP address could not be found."
Posted: Sun Jul 15, 2018 4:55 pm
Well, you need to replace with your own IP address. That's why I said to find the IP address in the status page of the controller.
Posted: Sun Jul 15, 2018 7:13 pm
by ReefingHavoc
Got it. I get an XML file
Posted: Sun Jul 15, 2018 9:02 pm
Can you paste here?
Posted: Mon Jul 16, 2018 2:23 pm
by ReefingHavoc
<RA>
<ID>ReefingHavoc</ID>
<T1>782</T1>
<T2>0</T2>
<T3>0</T3>
<PH>823</PH>
<R>0</R>
<RON>0</RON>
<ROFF>255</ROFF>
<R1>144</R1>
<RON1>0</RON1>
<ROFF1>255</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>0</ATOLOW>
<ATOHIGH>0</ATOHIGH>
<EM>1</EM>
<EM1>6</EM1>
<REM>1</REM>
<BID>4</BID>
<AF>0</AF>
<SF>0</SF>
<PWMA>0</PWMA>
<PWMD>55</PWMD>
<PWMAO>255</PWMAO>
<PWMDO>255</PWMDO>
<PWMA2>0</PWMA2>
<PWMD2>65</PWMD2>
<PWMA2O>255</PWMA2O>
<PWMD2O>255</PWMD2O>
<DCM>1</DCM>
<DCS>60</DCS>
<DCD>10</DCD>
<DCT>30</DCT>
<LEAK>0</LEAK>
<ALARM>0</ALARM>
<PWME0>0</PWME0>
<PWME0O>255</PWME0O>
<PWME1>0</PWME1>
<PWME1O>255</PWME1O>
<PWME2>0</PWME2>
<PWME2O>255</PWME2O>
<PWME3>0</PWME3>
<PWME3O>255</PWME3O>
<PWME4>0</PWME4>
<PWME4O>255</PWME4O>
<PWME5>0</PWME5>
<PWME5O>255</PWME5O>
</RA>
Posted: Mon Jul 16, 2018 5:23 pm
Ok, so it looks like everything is good with the controller.
It must be something on uapp.
Are you using the web based uapp?
Posted: Mon Jul 16, 2018 6:39 pm
by ReefingHavoc
I was using the web based uapp and for whatever reason, I'm now seeing the data. The refresh in the app didn't do anything, but when I did a hard refresh with the browser it loaded.
