Extension relay not showing in the portal
Posted: Thu Aug 16, 2018 7:49 am
by ganjero
My extension relay doe snot show up in the portal. What am I missing?
Thank you
Re: Extension relay not showing in the portal
Posted: Thu Aug 16, 2018 9:52 am
You are not sending data to the portal server.
Try updating the wifi attachment:
Posted: Thu Aug 16, 2018 5:33 pm
by ganjero
I had no power at home earlier , it is sending data just not showing the extension relay box.
Posted: Thu Aug 16, 2018 5:34 pm
No. it is not sending data.
You can see that your banner is empty.
Posted: Thu Aug 16, 2018 5:41 pm
by ganjero
weird, it shows on my computer the portal is connected.
Posted: Thu Aug 16, 2018 5:43 pm
by ganjero
see attached
Posted: Thu Aug 16, 2018 9:13 pm
That means you can connect live, but that doesn't mean you are sending data to the portal.
They are two independent things.
Posted: Mon Sep 17, 2018 1:39 pm
by sbidny
I am having the same issue. I have updated the wifi attachment firmware, but I still see the same problem. I can see the expansion relay on the controller and in the UApp, and I can interact with it on the UApp, but it's not showing up on the portal.
Other data seems correct on the portal, and I can interact with the main relay there. Does anyone have any suggestions?
Seems that I'm always up against some issue or another with my Reef Angel (e.g., constant Bluetooth adapter problems, salinity expansion not working, I/O expansion not working, this relay expansion issue, bus locks, initial connection issues, momentary incorrect temperatures).
-Steve
Posted: Mon Sep 17, 2018 9:07 pm
I don't think your wifi attachment was updated. There is no record of any data being sent to the portal server.
Posted: Mon Sep 17, 2018 9:12 pm
by sbidny
So I should just try updating it again?
How is the information on the portal updating if my information isn't being sent?
If I visit the r99 page for my controller, it seems to me that there is data, but it's missing the data for the expansion relay.
Posted: Tue Sep 18, 2018 9:45 am
Yes, update it again.
The portal has two modes.
Offline - data is sent to portal every 5 minutes. That's what generates the charts and historical data.
Online - You can control and monitor live data. The portal gets /r99 directly from controller but doesn't store anything.
Posted: Wed Sep 19, 2018 10:20 am
by sbidny
Tried updating again. Still no luck. The wifi utility doesn't show the current version number or the new version number, so it's difficult to tell if the update is successful.
As for the portal, I am seeing my information update "online," as it is definitely updating more than once every five minutes. I can also control my controller from the portal.
Not sure how to tell if the offline data is making it, but I'm confused as to which one (offline or online) is used to start displaying the second relay.
The /r99 address still doesn't seem to show the second relay. What would cause this if the controller itself is seeing the second relay?
Posted: Wed Sep 19, 2018 10:57 am
This is the line we are interested in when you run the tera term script to update the firmware:
The second relay will show up once you get the wifi attachment updated.
It is updating more than every 5 minutes because you are pulling data straight from the controller, but the portal needs historical data in its database.
Posted: Wed Sep 19, 2018 12:06 pm
by sbidny
I was trying to update the firmware from the WiFi utility. Is this incorrect?
Posted: Wed Sep 19, 2018 12:38 pm
Posted: Wed Sep 19, 2018 3:12 pm
by sbidny
Is there any way to confirm that the firmware update was successful? I went through the steps, and it seemed to accept the 'set i h 104.36.18.155' command, but the /r99 still looks the same. Not sure if it's supposed to change.
Posted: Wed Sep 19, 2018 3:18 pm
by sbidny
After waiting a bit, I now see the second relay showing up. Thanks!
Posted: Sat Dec 29, 2018 11:55 am
by ganjero
Still having this issue. Roberto could you check if my RA is now sending info out correctly. BTW I performed the upgraded in the link you provided.
Posted: Sat Dec 29, 2018 12:07 pm
Your banner is showing the second relay box.
What problem is that you are referring to?
