Is the cloud down?
Related to the Portal
PostPosted: Fri Dec 28, 2018 11:10 am
Ok. Good. Let me check this now.
PostPosted: Fri Dec 28, 2018 11:14 am
Also, I'm sure it's related but the UAPP is the same. Won't work, thinks user name is unknown.
PostPosted: Fri Dec 28, 2018 11:43 am
Try it again.
May need to refresh webwizard page.
PostPosted: Fri Dec 28, 2018 11:53 am
Great! That webwizard is functioning again! Thanks :)
UAPP is still broken though. Still have to log into the forum on ever page load (sometimes right after logging in)
PostPosted: Fri Dec 28, 2018 12:16 pm
Did you go to http or https when loading uapp?
PostPosted: Fri Dec 28, 2018 12:27 pm
I was having this problem as well (with needing to put password every time)
Also it seems that at night (1-3am at least...) this is my coding/debugging time and I see it takes a while for the RA to connect to the MQTT server. It sometimes takes 1-3 fails before I get a successful connection to the cloud. It does not seem like I have this problem during the day. if I reboot the controller it comes back online very quickly.
I had a few disconnects recently as well and had to restart the RA to reestablish the connection. not sure if there is something going on that's related here or not.
PostPosted: Fri Dec 28, 2018 12:40 pm
tkeracer619 wrote:Great! That webwizard is functioning again! Thanks :)
I have no problems on uapp on both http or https.
Where is that you are getting the forum login request? It doesn't depend on the forum cookies.
PostPosted: Fri Dec 28, 2018 12:41 pm
lnevo wrote:I was having this problem as well (with needing to put password every time)
It could be due to the reboots I had to do on the mqtt service when I implemented tsl over websockets
PostPosted: Fri Dec 28, 2018 12:43 pm
rimai wrote:Did you go to http or https when loading uapp?
Both.
I've always just gone to forum.reefangel.com/uapp
but neither https or http work for me. Just says unknown forum username.
Whenever I go out of the forums to the rest of the website, come to the forums with a new browser page or tab (even if logged in on another tab), or to the portal.
sometimes I'll log in and it won't take and I have to do it a second time for it to take.
PostPosted: Fri Dec 28, 2018 12:51 pm
I see.
The link is sending you to http when you leave the forums.
I'll fix it.
But unknown forum username means you don't have a controller profile setup yet.
Return to Portal
