Is the cloud down?
Related to the Portal
PostPosted: Fri Dec 28, 2018 12:53 pm
rimai wrote:I see.
The link is sending you to http when you leave the forums.
I'll fix it.
But unknown forum username means you don't have a controller profile setup yet.
Thanks! Yeah... I just realized that. When I was swapping between browsers to see if it was my chrome I forgot I did another history wipe... durp :roll:
PostPosted: Tue Jan 01, 2019 1:50 pm
For some reason mine will only work on IE. Any attempts to use chrome or to access the uapp on my iphone via safari is unsuccessful. Any input here?
PostPosted: Tue Jan 01, 2019 4:07 pm
I tried on all kinds of browser and they all worked, including safari on iphone and chrome on w10.
What is the problem you are seeing?
PostPosted: Wed Jan 02, 2019 11:10 am
It was giving me the "unable to process controller data" on safari and chrome, but worked on IE for whatever reason.
Later in the day it was functioning as normal and is fine today.
PostPosted: Tue Jan 15, 2019 11:17 am
Having some issues with the uApp, and wondering if it's related. On my browser the uApp works fine, my phone is getting a timeout error but was working fine 2 days ago. Tried to reboot the controller, but it didn't resolve the issue. Noticed that on the top of the controller screen there was a firmware upload failed. I haven't tried to upload anything in the past month.
PostPosted: Tue Jan 15, 2019 11:44 am
Is it with the cloud wifi or regular wifi attachment?
PostPosted: Tue Jan 15, 2019 11:45 am
Nevermind. It is with Star.
You should create a profile without ip address and port to use it as a cloud connected.
PostPosted: Tue Jan 15, 2019 3:15 pm
Looks like Curt's app still updates fine. Only the mobile phone version of the UApp isn't working. Maybe the controller needs a reboot. I'll check when I get home.
PostPosted: Wed Jan 16, 2019 10:28 am
The issue turns out to be that my ISP changed my IP address.
PostPosted: Wed Jan 16, 2019 10:51 am
Ok, but you are still not taking advantage of the cloud connected feature.
When you use the cloud server on uapp, you don't have to worry about ip address changes or port forwarding.
Also, using the cloud lets you stream data and you are always receiving data that updates automatically on the screen then moment they happen on the controller. Using ip address/port, you need to hit refresh everytime.
To use the cloud feature, when setting up your profile, you need to leave the ip address/port blank.
Delete the current one instead of erasing the fields. I think there is a lingering effect when you just blank the fields instead if leaving it blank when setting up.
Return to Portal
