Webwizard - Error compiling: [object Object]
Posted: Tue Jan 01, 2019 4:29 am
by libertyaquarium
Hi
Since yesterday I am getting this error when try to compile any code in webwizard
"Error compiling: [object Object]"
I am using windows 10. Unistalled the pluging and installed again, no effect.
As I said, even the simplest code get this result
Re: Webwizard - Error compiling: [object Object]
Posted: Tue Jan 01, 2019 11:40 am
Try again.
Posted: Tue Jan 01, 2019 11:41 am
But I would recommend you accessing it over ssl on
https://forum.reefangel.com/webwizard so your forum login gets preserved over the entire session.
Posted: Tue Jan 01, 2019 11:59 am
by libertyaquarium
Roberto
Still the same.
That's what I do: I go to forum.reefangel.com, log in using login and password, change the URL address to /webwizard (does not show me the message about logging in). Everything using HTTPS.
Still any code submited gets "Error compiling: [object Object]"
Posted: Tue Jan 01, 2019 12:31 pm
Can you try with the existing default code that already shows up when you go to webwizard?
Does it show the same error?
Try refreshing the webwizard page.
Posted: Tue Jan 01, 2019 1:03 pm
by libertyaquarium
Roberto
Take a look at
https://sgapucminasbr-my.sharepoint.com ... g?e=liYgeC
I cleared all the browsing data (history, images, files, cookies and other site data). The same happened.
Posted: Tue Jan 01, 2019 3:36 pm
That prompt for the certificate is very strange.
I can't replicate that on any browser I tried.
Posted: Wed Jan 02, 2019 8:03 am
by libertyaquarium
Crazy... I did not accepted and run properly....
