Unreachable address RA star
Related to the Portal
SouthernReefer
Post by SouthernReefer »
I have gone into my profile and added the address star grabbed on my network. I still get address unreachable using port 2000. I know o don't have to port forward, but is there any guide for setting up portal? Looked but couldn't find one. I can log onto my router if I need to make changes there. Looking for access here rt the house and remote
SouthernReefer
Re: Unreachable address RA star
Came across the uapp app and webpage in more reading.nim assuming that this is the way to go? Struggling to find which port I'm supposed to use, and if I need to go into my router and open it etc.
SouthernReefer
I went in and added port 2000 to my router config for the IP address. I believe it's working. I'll know more once tanks wet of I can play with relays but I think I'm good now.
SouthernReefer
So I can get to it internally but externally I get a timeout when. Itry to do anything. I connected to just data and can't get there. Any ideas on what I need to allow ?
If you have the RA*, use the UApp and don't enter anything for ip address nor port. Simply add the forum username and password when creating the profile.
This way you won't need to worry about any port forwarding.
SouthernReefer
rimai wrote:If you have the RA*, use the UApp and don't enter anything for ip address nor port. Simply add the forum username and password when creating the profile.
It's the RA Star. Is it the same behavior? I added in port 2000 as allowed for the IP it got and I can get to it internally, but not from outside the house.
The RA* is capable of using the cloud server.
The advantage is that you don't need to setup any port forwarding and it will work inside or outside of your wifi network.
SouthernReefer
rimai wrote:The RA* is capable of using the cloud server.
I think that is where i am confused. In Uapp what do i need to then configure to allow myself access to star anywhere, as i have network info in there, and opened port 2000, but if i can get rid of that, and not have to worry about it great! also i noticed in another post about DDNS. is that what i then need to setup, as i do have my network on DHCP so the Star will change addresses at somepoint im sure.
On RA*, don't worry about ip address, port, ddns or port forwarding.
Use Uapp and the cloud server.
Simply delete the profile you have and add a new one and enter only the forum username and password.
SouthernReefer
rimai wrote:On RA*, don't worry about ip address, port, ddns or port forwarding.
Excellent. I just tried it in the app, so maybe im missing something, but it wont let me continue without IP and or Port. Is there a link to the newest version? maybe i have an older version? on The Uapp webpage as well i cant find where to log in, other then it just pulling over my session from the forum. Im assuming thats what its doing?
SouthernReefer
Found where on the Uapp page to login, but it wont connect. I just get connecting status.
Did you add a new profile?
SouthernReefer
rimai wrote:Did you add a new profile?
Yep. I deleted it completely, Named the controller, and then added my creds for the forum. The head unit does say cloud connected.
Can you open uapp on Chrome and press F12 to get developer tools?
Then copy paste the log.
SouthernReefer
u app error.png (51.2 KiB) Viewed 4591 times
u app error 2.png (7.98 KiB) Viewed 4591 times
SouthernReefer
rimai wrote:Can you open uapp on Chrome and press F12 to get developer tools?
I went in and did a few things, or tried to.
forum.reefangel.com/:328 GET https://forum.reefangel.com/Uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:323 GET https://forum.reefangel.com/Uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:325 GET https://forum.reefangel.com/Uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:336 GET https://forum.reefangel.com/Uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:330 GET https://forum.reefangel.com/Uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:334 GET https://forum.reefangel.com/Uapp/images ... %7D%7D.png 404 (Not Found)
DevTools failed to load SourceMap: Could not load content for https://forum.reefangel.com/Uapp/js/ang ... min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
uapp.js:613 {RA: {…}}
uapp.js:1112 UpdateParams()
uapp.js:2165 MQTTconnect(): cloudusername=southernreefer, cloudpassword= NaN
forum.reefangel.com/:576 GET https://forum.reefangel.com/Uapp/images ... mage%7D%7D 404 (Not Found)
forum.reefangel.com/:344 GET https://forum.reefangel.com/Uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:338 GET https://forum.reefangel.com/Uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:342 GET https://forum.reefangel.com/Uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:340 GET https://forum.reefangel.com/Uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:667 GET https://forum.reefangel.com/Uapp/images ... mage%7D%7D 404 (Not Found)
uapp.js:2177 Connection Failure: code=1, message=AMQJSC0001E Connect timed out.
uapp.js:104 getcontrollerdata(): d
angular.js:12330 Error: Failed to execute 'open' on 'XMLHttpRequest': Invalid URL
at angular.js:10453
at sendReq (angular.js:10333)
at serverRequest (angular.js:10045)
at processQueue (angular.js:14567)
at angular.js:14583
at Scope.$eval (angular.js:15846)
at Scope.$digest (angular.js:15657)
at ChildScope.$apply (angular.js:15951)
at HTMLElement.listener (onsenui.js:20467)
at HTMLElement.eventHandler (angular.js:3271)
(anonymous) @ angular.js:12330
(anonymous) @ angular.js:9109
processQueue @ angular.js:14575
(anonymous) @ angular.js:14583
$eval @ angular.js:15846
$digest @ angular.js:15657
$apply @ angular.js:15951
listener @ onsenui.js:20467
eventHandler @ angular.js:3271
uapp.js:218 Unable to process controller data! Retry: 1
at angular.js:10453
at angular.js:14583
mqttws31-min.js:36 WebSocket connection to 'wss://cloud.reefangel.com:9002/mqtt' failed: Error in connection establishment: net::ERR_CONNECTION_TIMED_OUT
k._doConnect @ mqttws31-min.js:36
k.connect @ mqttws31-min.js:31
I.connect @ mqttws31-min.js:65
MQTTconnect @ uapp.js:2187
UpdateParams @ uapp.js:1127
(anonymous) @ uapp.js:614
invoke @ angular.js:4450
extend.instance @ angular.js:8999
nodeLinkFn @ angular.js:8109
compositeLinkFn @ angular.js:7541
compositeLinkFn @ angular.js:7545
nodeLinkFn @ angular.js:8145
publicLinkFn @ angular.js:7416
_loadPageDOM @ onsenui.js:13857
(anonymous) @ onsenui.js:13801
processQueue @ angular.js:14567
bootstrapApply @ angular.js:1633
doBootstrap @ angular.js:1631
bootstrap @ angular.js:1651
(anonymous) @ onsenui.js:5590
uapp.js:414 Parameterslabels
uapp.js:743 PopoverControllerlabels
at angular.js:10453
at angular.js:14583
at angular.js:10453
at angular.js:14583
k._disconnected @ mqttws31-min.js:54
(anonymous) @ mqttws31-min.js:28
For this method of connection (using the cloud server), there is no need to hit refresh. Data would just be streaming and updating on the screen live as it changes.
But, your log shows your connection is timing out for some reason.
Can you try the same thing on your phone using 4G?
Make sure you are not connected to your wifi network.
I am just trying to figure out if there is any block from within your wifi network.
SouthernReefer
rimai wrote:Make sure you are not connected to your wifi network.
I am on the network, i was trying from a PC. How do i create the account in the U app app? Theres no where to enter my credentials for the forum. when i add controller it wants IP address name and port. version 1.0.2 is what is installed. Does this mean i cant connect to the controller via tablet in the house? Its going to be easier to do that for some modes until i configure ALexa control for modes.
SouthernReefer
tried on LTE over my phone to just the webpage for Uapp. Created a new profile again with just a name to the controller and the forum credentials.
No dice. I got it working last night by putting in the IP and the port, but thats the only way it would work.
The uapp app is outdated. I thought it had even been removed from the store. Is it still there? Apple, right?
It is so much easier to just use webpage app and create a shortcut to your home screen.
The method you got it working is with ip address and port, which requires port forwarding on your router to access from outside your wifi and it also requires you to keep hitting refresh button to grab new values.
The cloud is the best method for RA*.
Try on both http and https pages.
http://forum.reefangel.com/uapp
and
https://forum.reefangel.com/uapp
I wonder if that will make any difference
SouthernReefer
rimai wrote:The uapp app is outdated. I thought it had even been removed from the store. Is it still there? Apple, right?
and
Well that makes sense. Android. I was reading here late last night, and found the link to install. Ill remove it and do the web page then. I have a dedicated tablet to control from, as well as my phone.
Here is the HTTP F12 developer console report.
uapp.js:613 Object
/uapp/images/%7B%7Batohigh%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Batolow%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Balarm%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bleak%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bio1%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bio0%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bio2%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bio3%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bio4%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bio5%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bdcimage%7D%7D:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Brfimage%7D%7D:1 Failed to load resource: the server responded with a status of 404 (Not Found)
DevTools failed to load SourceMap: Could not load content for http://forum.reefangel.com/uapp/js/angu ... min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
uapp.js:2192 MQTTdisconnect()
2uapp.js:623 Settingsparamsok
uapp.js:743 PopoverControllerparamsok
2uapp.js:623 Settingspopoverclose
uapp.js:743 PopoverControllerpopoverclose
SouthernReefer
and
both from PC first but heres https:
forum.reefangel.com/:323 GET https://forum.reefangel.com/uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:325 GET https://forum.reefangel.com/uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:328 GET https://forum.reefangel.com/uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:330 GET https://forum.reefangel.com/uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:334 GET https://forum.reefangel.com/uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:336 GET https://forum.reefangel.com/uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:338 GET https://forum.reefangel.com/uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:340 GET https://forum.reefangel.com/uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:342 GET https://forum.reefangel.com/uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:344 GET https://forum.reefangel.com/uapp/images ... %7D%7D.png 404 (Not Found)
forum.reefangel.com/:576 GET https://forum.reefangel.com/uapp/images ... mage%7D%7D 404 (Not Found)
forum.reefangel.com/:667 GET https://forum.reefangel.com/uapp/images ... mage%7D%7D 404 (Not Found)
DevTools failed to load SourceMap: Could not load content for https://forum.reefangel.com/uapp/js/ang ... min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
SouthernReefer
and
Android phone and tablet. But i tried on LTE on my phone with same stuff. It goes to connecting to disconnected very quick.
SouthernReefer
Its on my network on a wifi extender connected to my Nighthawk Router via WPS.
Go to http://www.hivemq.com/demos/websocket-client/
Host: cloud.reefangel.com
Port: 9001
Username: SouthernReefer
Password: your forum password
Click connect.
Are you able to establish connection?
SouthernReefer
rimai wrote:Go to http://www.hivemq.com/demos/websocket-client/
Port: 9001
Click connect.
No dice
SouthernReefer
I tried on wifi and on LTE. Same on both.
Try using the username with the same case. It is case sensitive.
SouthernReefer
rimai wrote:Try using the username with the same case. It is case sensitive.
That was it! I didn't realize it was case sensitive. I was able to connect via the page you sent me, and from uapp. I'm so used to the sites I work with and support not being case sensitive, thst I didn't even think of that. Good to know! All set now! Thanks sir!!!!
