Unreachable address RA star
Related to the Portal
PostPosted: Tue Sep 29, 2020 9:27 am
Found where on the Uapp page to login, but it wont connect. I just get connecting status.
PostPosted: Tue Sep 29, 2020 9:31 am
Did you add a new profile?
PostPosted: Tue Sep 29, 2020 9:36 am
rimai wrote:Did you add a new profile?
Yep. I deleted it completely, Named the controller, and then added my creds for the forum. The head unit does say cloud connected.
PostPosted: Tue Sep 29, 2020 9:42 am
Can you open uapp on Chrome and press F12 to get developer tools?
Then copy paste the log.
u app error.png (51.2 KiB) Viewed 464 times
u app error 2.png (7.98 KiB) Viewed 464 times
PostPosted: Tue Sep 29, 2020 9:44 am
rimai wrote:Can you open uapp on Chrome and press F12 to get developer tools?
I went in and did a few things, or tried to.
forum.reefangel.com/:328 GET Uapp/images/%7B%7Balarm%7D%7D.png 404 (Not Found)
forum.reefangel.com/:323 GET Uapp/images/%7B%7Batohigh%7D%7D.png 404 (Not Found)
forum.reefangel.com/:325 GET Uapp/images/%7B%7Batolow%7D%7D.png 404 (Not Found)
forum.reefangel.com/:336 GET Uapp/images/%7B%7Bio1%7D%7D.png 404 (Not Found)
forum.reefangel.com/:330 GET Uapp/images/%7B%7Bleak%7D%7D.png 404 (Not Found)
forum.reefangel.com/:334 GET Uapp/images/%7B%7Bio0%7D%7D.png 404 (Not Found)
DevTools failed to load SourceMap: Could not load content for Uapp/js/angular-animate.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
uapp.js:613 {RA: {…}}
uapp.js:1112 UpdateParams()
uapp.js:2165 MQTTconnect(): cloudusername=southernreefer, cloudpassword= NaN
forum.reefangel.com/:576 GET Uapp/images/%7B%7Brfimage%7D%7D 404 (Not Found)
forum.reefangel.com/:344 GET Uapp/images/%7B%7Bio5%7D%7D.png 404 (Not Found)
forum.reefangel.com/:338 GET Uapp/images/%7B%7Bio2%7D%7D.png 404 (Not Found)
forum.reefangel.com/:342 GET Uapp/images/%7B%7Bio4%7D%7D.png 404 (Not Found)
forum.reefangel.com/:340 GET Uapp/images/%7B%7Bio3%7D%7D.png 404 (Not Found)
forum.reefangel.com/:667 GET Uapp/images/%7B%7Bdcimage%7D%7D 404 (Not Found)
uapp.js:2177 Connection Failure: code=1, message=AMQJSC0001E Connect timed out.
uapp.js:104 getcontrollerdata(): d
angular.js:12330 Error: Failed to execute 'open' on 'XMLHttpRequest': Invalid URL
at angular.js:10453
at sendReq (angular.js:10333)
at serverRequest (angular.js:10045)
at processQueue (angular.js:14567)
at angular.js:14583
at Scope.$eval (angular.js:15846)
at Scope.$digest (angular.js:15657)
at ChildScope.$apply (angular.js:15951)
at HTMLElement.listener (onsenui.js:20467)
at HTMLElement.eventHandler (angular.js:3271)
(anonymous) @ angular.js:12330
(anonymous) @ angular.js:9109
processQueue @ angular.js:14575
(anonymous) @ angular.js:14583
$eval @ angular.js:15846
$digest @ angular.js:15657
$apply @ angular.js:15951
listener @ onsenui.js:20467
eventHandler @ angular.js:3271
uapp.js:218 Unable to process controller data! Retry: 1
at angular.js:10453
at angular.js:14583
mqttws31-min.js:36 WebSocket connection to 'wss://cloud.reefangel.com:9002/mqtt' failed: Error in connection establishment: net::ERR_CONNECTION_TIMED_OUT
k._doConnect @ mqttws31-min.js:36
k.connect @ mqttws31-min.js:31
I.connect @ mqttws31-min.js:65
MQTTconnect @ uapp.js:2187
UpdateParams @ uapp.js:1127
(anonymous) @ uapp.js:614
invoke @ angular.js:4450
extend.instance @ angular.js:8999
nodeLinkFn @ angular.js:8109
compositeLinkFn @ angular.js:7541
compositeLinkFn @ angular.js:7545
nodeLinkFn @ angular.js:8145
publicLinkFn @ angular.js:7416
_loadPageDOM @ onsenui.js:13857
(anonymous) @ onsenui.js:13801
processQueue @ angular.js:14567
bootstrapApply @ angular.js:1633
doBootstrap @ angular.js:1631
bootstrap @ angular.js:1651
(anonymous) @ onsenui.js:5590
uapp.js:414 Parameterslabels
uapp.js:743 PopoverControllerlabels
at angular.js:10453
at angular.js:14583
at angular.js:10453
at angular.js:14583
k._disconnected @ mqttws31-min.js:54
(anonymous) @ mqttws31-min.js:28
PostPosted: Tue Sep 29, 2020 9:57 am
For this method of connection (using the cloud server), there is no need to hit refresh. Data would just be streaming and updating on the screen live as it changes.
But, your log shows your connection is timing out for some reason.
Can you try the same thing on your phone using 4G?
Make sure you are not connected to your wifi network.
I am just trying to figure out if there is any block from within your wifi network.
PostPosted: Tue Sep 29, 2020 10:02 am
rimai wrote:Make sure you are not connected to your wifi network.
I am on the network, i was trying from a PC. How do i create the account in the U app app? Theres no where to enter my credentials for the forum. when i add controller it wants IP address name and port. version 1.0.2 is what is installed. Does this mean i cant connect to the controller via tablet in the house? Its going to be easier to do that for some modes until i configure ALexa control for modes.
PostPosted: Tue Sep 29, 2020 10:05 am
tried on LTE over my phone to just the webpage for Uapp. Created a new profile again with just a name to the controller and the forum credentials.
No dice. I got it working last night by putting in the IP and the port, but thats the only way it would work.
Return to Portal
