Unreachable address RA star
Related to the Portal
PostPosted: Tue Sep 29, 2020 10:11 am
The uapp app is outdated. I thought it had even been removed from the store. Is it still there? Apple, right?
It is so much easier to just use webpage app and create a shortcut to your home screen.
The method you got it working is with ip address and port, which requires port forwarding on your router to access from outside your wifi and it also requires you to keep hitting refresh button to grab new values.
The cloud is the best method for RA*.
Try on both http and https pages.
http://forum.reefangel.com/uapp
and
uapp
I wonder if that will make any difference
PostPosted: Tue Sep 29, 2020 10:14 am
rimai wrote:The uapp app is outdated. I thought it had even been removed from the store. Is it still there? Apple, right?
and
uapp
Well that makes sense. Android. I was reading here late last night, and found the link to install. Ill remove it and do the web page then. I have a dedicated tablet to control from, as well as my phone.
Here is the HTTP F12 developer console report.
uapp.js:613 Object
uapp.js:1112 UpdateParams()
/uapp/images/%7B%7Batohigh%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Batolow%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Balarm%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bleak%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bio1%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bio0%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bio2%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bio3%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bio4%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bio5%7D%7D.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Bdcimage%7D%7D:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/uapp/images/%7B%7Brfimage%7D%7D:1 Failed to load resource: the server responded with a status of 404 (Not Found)
DevTools failed to load SourceMap: Could not load content for http://forum.reefangel.com/uapp/js/angu ... min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
uapp.js:2192 MQTTdisconnect()
2uapp.js:623 Settingsparamsok
uapp.js:743 PopoverControllerparamsok
2uapp.js:623 Settingspopoverclose
uapp.js:743 PopoverControllerpopoverclose
uapp.js:613 {RA: {…}}
uapp.js:2165 MQTTconnect(): cloudusername=southernreefer, cloudpassword= NaN
uapp.js:2177 Connection Failure: code=1, message=AMQJSC0001E Connect timed out.
mqttws31-min.js:36 WebSocket connection to 'wss://cloud.reefangel.com:9002/mqtt' failed: Error in connection establishment: net::ERR_CONNECTION_TIMED_OUT
k._doConnect @ mqttws31-min.js:36
k.connect @ mqttws31-min.js:31
I.connect @ mqttws31-min.js:65
MQTTconnect @ uapp.js:2187
UpdateParams @ uapp.js:1127
(anonymous) @ uapp.js:614
invoke @ angular.js:4450
extend.instance @ angular.js:8999
nodeLinkFn @ angular.js:8109
compositeLinkFn @ angular.js:7541
compositeLinkFn @ angular.js:7545
nodeLinkFn @ angular.js:8145
publicLinkFn @ angular.js:7416
_loadPageDOM @ onsenui.js:13857
(anonymous) @ onsenui.js:13801
processQueue @ angular.js:14567
(anonymous) @ angular.js:14583
$eval @ angular.js:15846
$digest @ angular.js:15657
$apply @ angular.js:15951
listener @ onsenui.js:20467
eventHandler @ angular.js:3271
PostPosted: Tue Sep 29, 2020 10:15 am
and
uapp
both from PC first but heres https:
forum.reefangel.com/:323 GET uapp/images/%7B%7Batohigh%7D%7D.png 404 (Not Found)
forum.reefangel.com/:325 GET uapp/images/%7B%7Batolow%7D%7D.png 404 (Not Found)
forum.reefangel.com/:328 GET uapp/images/%7B%7Balarm%7D%7D.png 404 (Not Found)
forum.reefangel.com/:330 GET uapp/images/%7B%7Bleak%7D%7D.png 404 (Not Found)
forum.reefangel.com/:334 GET uapp/images/%7B%7Bio0%7D%7D.png 404 (Not Found)
forum.reefangel.com/:336 GET uapp/images/%7B%7Bio1%7D%7D.png 404 (Not Found)
forum.reefangel.com/:338 GET uapp/images/%7B%7Bio2%7D%7D.png 404 (Not Found)
forum.reefangel.com/:340 GET uapp/images/%7B%7Bio3%7D%7D.png 404 (Not Found)
forum.reefangel.com/:342 GET uapp/images/%7B%7Bio4%7D%7D.png 404 (Not Found)
forum.reefangel.com/:344 GET uapp/images/%7B%7Bio5%7D%7D.png 404 (Not Found)
forum.reefangel.com/:576 GET uapp/images/%7B%7Brfimage%7D%7D 404 (Not Found)
forum.reefangel.com/:667 GET uapp/images/%7B%7Bdcimage%7D%7D 404 (Not Found)
DevTools failed to load SourceMap: Could not load content for uapp/js/angular-animate.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
PostPosted: Tue Sep 29, 2020 10:18 am
and
uapp
Android phone and tablet. But i tried on LTE on my phone with same stuff. It goes to connecting to disconnected very quick.
Its on my network on a wifi extender connected to my Nighthawk Router via WPS.
PostPosted: Tue Sep 29, 2020 4:59 pm
Go to http://www.hivemq.com/demos/websocket-client/
Host: cloud.reefangel.com
Port: 9001
Username: SouthernReefer
Password: your forum password
Click connect.
Are you able to establish connection?
PostPosted: Tue Sep 29, 2020 5:21 pm
rimai wrote:Go to http://www.hivemq.com/demos/websocket-client/
Port: 9001
Click connect.
No dice
PostPosted: Tue Sep 29, 2020 5:25 pm
I tried on wifi and on LTE. Same on both.
PostPosted: Tue Sep 29, 2020 5:29 pm
Try using the username with the same case. It is case sensitive.
PostPosted: Tue Sep 29, 2020 5:50 pm
rimai wrote:Try using the username with the same case. It is case sensitive.
That was it! I didn't realize it was case sensitive. I was able to connect via the page you sent me, and from uapp. I'm so used to the sites I work with and support not being case sensitive, thst I didn't even think of that. Good to know! All set now! Thanks sir!!!!
Return to Portal
