My RA* is connected via ethernet and says it has a cloud connection. The Uapp even reports that it's connected. However, any changes I make to labels in the portal are no reflected in the Uapp nor on the RA*.
It times out.
Portal changes and Uapp timeout
- Screen Shot 2020-10-26 at 11.45.05 AM.png (23.07 KiB) Viewed 2714 times
Re: Portal changes and Uapp timeout
Have you chosen to "Download labels from portal" from the uapp?
As for the star, the labels are set via the code and not retrieved from the portal.
