How to use the trigger options in the Portal
Re: How to use the trigger options in the Portal
i don't use ReefAngel.Portal() is the server to get the value. i don't have space for send parameters...
work
<RA>
<T1>268</T1>
<T2>0</T2>
<T3>0</T3>
<PH>642</PH>
<R>11</R>
<RON>0</RON>
<ROFF>255</ROFF>
<ATOLOW>0</ATOLOW>
<ATOHIGH>1</ATOHIGH>
<EM>0</EM>
<REM>0</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>0</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
<RA>
<T1>268</T1>
<T2>0</T2>
<T3>0</T3>
<PH>642</PH>
<R>11</R>
<RON>0</RON>
<ROFF>255</ROFF>
<ATOLOW>0</ATOLOW>
<EM>0</EM>
<REM>0</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>0</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
i put this trigger:
T1 <= 24 Temp too less
T1 >= 27.5 Temp too high
RON > 0 Relay force on
ROFF < 255 Relay force off
C0 = 1 ATO Alarm
C1 = 1 Overheat Alarm
C0 = 1 ATO Alarm
i try the ATO Alarm , C0=1... but i see that the alarm don't arrive.
so i try to connect to wifi of the controller... but not work. /wifi or /r99 nothing ......
i restart my controller, but nothing the web server don't respond....
i try to clear the ato alarm and..... magically the web server work!
there is some bug to customs ?
The alarm is only sent when the data is sent to the portal. If you are only sending the data every 3 minutes, then it can take up to 3 minutes for the alarm to be sent once it is triggered. Also, make sure you are setting the alarm / custom variable BEFORE the call to Portal() (or webbanner()). Otherwise, the value will not be sent until the next time it is sent (which could be another 3 minutes later).
the problem is not the alarm...but the internal web server of the RA.
When the ato alarm is on and the c0=1 the internal web server of the RA don't work.
when i write on my browser ip:2000/wifi o /r99 it not answer
This is the code I use to test:
With this features:
When I pull the data without timeout, I get this:
When I pull data with the timeout, I get this:
I could not get the same behavior you experienced.
Can you post your code and features?
ReefAngel.Init();
ReefAngel.SingleATO(true,Port1,4,1);
if ( InternalMemory.read(ATO_Single_Exceed_Flag) == 1 )
ReefAngel.CustomVar[0]=1;
ReefAngel.CustomVar[0]=0;
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#define ENABLE_EXCEED_FLAGS
#define CUSTOM_VARIABLES
HTTP/1.1 200 OK
Server: ReefAngel
Pragma: no-cache
Connection: close
Content-Type: text/xml
Content-Length: 257
<RA><T1>0</T1><T2>0</T2><T3>0</T3><PH>505</PH><R>0</R><RON>0</RON><ROFF>255</ROFF><ATOLOW>0</ATOLOW><ATOHIGH>0</ATOHIGH><EM>0</EM><REM>0</REM><PWMA>20</PWMA><PWMD>20</PWMD><C0>0</C0><C1>0</C1><C2>0</C2><C3>0</C3><C4>0</C4><C5>0</C5><C6>0</C6><C7>0</C7></RA>
HTTP/1.1 200 OK
Server: ReefAngel
Pragma: no-cache
Connection: close
Content-Length: 257
<RA><T1>0</T1><T2>0</T2><T3>0</T3><PH>504</PH><R>0</R><RON>0</RON><ROFF>255</ROFF><ATOLOW>0</ATOLOW><ATOHIGH>0</ATOHIGH><EM>0</EM><REM>0</REM><PWMA>20</PWMA><PWMD>20</PWMD><C0>1</C0><C1>0</C1><C2>0</C2><C3>0</C3><C4>0</C4><C5>0</C5><C6>0</C6><C7>0</C7></RA>
this is my pde
if you want, this evening i retry it
with the new version the dosingpump repeat don't work.... or i' m not able....// Autogenerated file by RAGen (v1.2.1.158), (02/21/2012 19:09)
// RA_022112_1909.ino
#define wifi
#define WDT
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define ENABLE_ATO_LOGGING
int DP3_Timer = InternalMemory.DP1Timer_read() * 4;
ReefAngel.LCD.DrawMonitor(15, 10, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 10, ReefAngel.Params);
byte x = 8;
byte y = 45;
char text[7];
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x, y, "DP1:");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+25, y, InternalMemory.DP1Timer_read());
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+37, y, "DP2:");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+62, y, InternalMemory.DP2Timer_read());
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+75, y, "DP3:");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+101, y, DP3_Timer);
x = 6;
y += MENU_START_ROW+6;
y -= 3;
ReefAngel.LCD.Clear(COLOR_BLACK, x, y, 124, y);
y +=1;
ReefAngel.LCD.Clear(COLOR_BLUE, x+1, y, 123, y+10);
y +=11;
ReefAngel.LCD.Clear(COLOR_BLACK, x, y-11, x, y+16);
ReefAngel.LCD.Clear(COLOR_BLACK, 124, y-11, 124, y+16);
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_BLUE, x+40, y-9, "Alarms");
y += 6;
x += 2;
byte fcolor;
// This is for the LOW Ato switch
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+2, y,"ATO:");
// add in InternalMemory.write(700, 1) when ato is tripped
// add in InternalMemory.write(700, 0) when ato is cleared
fcolor = COLOR_RED;
ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+30, y, "YES");
fcolor = COLOR_GREEN;
ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+30, y, "NO ");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+55, y,"OverH:");
if ( InternalMemory.read(Overheat_Exceed_Flag) == 1 )
// add in InternalMemory.write(701, 1) when overheat is tripped
// add in InternalMemory.write(701, 0) when overheat is cleared
fcolor = COLOR_RED;
strcpy(text, "YES");
strcpy(text, "NO ");
ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+94, y, text);
ReefAngel.LCD.Clear(COLOR_BLACK, x-2, y+11, 124, y+11);
ReefAngel.LCD.DrawOutletBox(12, 95, TempRelay);
// ReefAngel.LCD.DrawGraph(5, 5);
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
// Specific functions
ReefAngel.StandardFan(Port1);
ReefAngel.MHLights(Port2);
// ReefAngel.DosingPump1(Port3);
//ReefAngel.DosingPumpRepeat(Port3, 0, 360, InternalMemory.DP1Timer_read());
ReefAngel.Relay.DelayedOn(Port4, 5);
// ReefAngel.DosingPump2(Port5);
//ReefAngel.DosingPumpRepeat(Port5, 10, 360, InternalMemory.DP2Timer_read());
ReefAngel.SingleATOHigh(Port6);
ReefAngel.StandardHeater(Port8);
ReefAngel.DosingPump(Port3, 1, 23, 20, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 05, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 11, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 17, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port5, 2, 23, 30, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 05, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 11, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 17, 10, InternalMemory.DP2Timer_read());
// ReefAngel.DosingPump(Port7, 23, 20, DP3_Timer); // Setup Dosing Pump 3 Oligo
ReefAngel.CustomVar[1]=1;
ReefAngel.CustomVar[1]=0;
Did you download 0.9.2 for the dosing pump fix?
I'll look over your code to see what I get.
Just to confirm, but you do have this on the features file, righ?
I tested your code and got the same thing I posted earlier.
Seems it is working fine here.
i try it now...and it's work
<RA><T1>266</T1><T2>0</T2><T3>0</T3><PH>924</PH><R>11</R><RON>0</RON><ROFF>255</ROFF><ATOLOW>0</ATOLOW><ATOHIGH>0</ATOHIGH><EM>0</EM><REM>0</REM><PWMA>0</PWMA><PWMD>0</PWMD><C0>1</C0><C1>0</C1><C2>0</C2><C3>0</C3><C4>0</C4><C5>0</C5><C6>0</C6><C7>0</C7></RA>
Hi,
i enable the Portal in my .ino code, and it' s work.
Now, i have the ATO in Alarms :
<RA><T1>270</T1><T2>0</T2><T3>0</T3><PH>665</PH><R>15</R><RON>0</RON><ROFF>255</ROFF><ATOLOW>0</ATOLOW><ATOHIGH>1</ATOHIGH><EM>0</EM><REM>0</REM><PWMA>0</PWMA><PWMD>0</PWMD><C0>1</C0><C1>0</C1><C2>0</C2><C3>0</C3><C4>0</C4><C5>0</C5><C6>0</C6><C7>0</C7></RA>
i set the trigger, but the portal don't send the email.
What is wrong ?
What is wrong ?
Roberto, have any news?
Yes, it should've been fixed a while ago.
Sorry I forgot to post.
Can you try?
Can you try?
i don't try it....rimai wrote:Yes, it should've been fixed a while ago.
Can you try?
but,
do you think is possible add at the trigger a lable ?
for example i set this:
T1 <= 23.7
T1 >= 27.5
RON > 0
C0 = 1
C1 = 1
Is possible add a lable, so the email object use it ?
Like :
T1 <= 23.7 Label: Water temp too low
T1 >= 27.5 Label: Water temp too high
RON > 0 Label: test
C0 = 1 Label: ATO Alarm
C1 = 1 Label: Overheat Alarm
Do you think is possible configure a rearm ?
TNX
I think it already sends the trigger as well as the actual value, so you know exactly what happened.
The trigger is always active and will send alerts every consecutive hour if the alert condition is still active.
I am trying to do similar. I would like to set a custom variable when the ATO timeout is exceeded. The code compiles fine, but my custom variable is not set for some reason. Here are (I think) the relevant portions of my ino file:
When compiling I get this output, which I think indicates the exceed flagging is enabled, and which I think is required for the custom ATO function to set the ato flag properly:
What the heck am I missing?
#define DisplayImages
#define SetupExtras
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define wifi
#define SaveRelayState
#define RelayExp
#define DosingPumpIntervalSetup
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 9
#define CUSTOM_MAIN
#define COLORS_PDE
#define IOEXPANSION
#define FONT_8x8
#define FONT_8x16
#define FONT_12x16
#define NUMBERS_8x8
#define NUMBERS_8x16
#define NUMBERS_12x16
#define NUMBERS_16x16
#include <avr/pgmspace.h>
void MyCustomATO(int ATOTimeout)
This function works as follows:
When it's time to topoff the system, we check the levels of each
of the three reservoirs. If a reservoir is empty, we set a custom
flag to indicate it's empty on the portal and we do not start that
pump. Otherwise, we clear the custom flag for the reservoir and
start the pump.
The function monitors the switch levels like normal.
Monitor the status of the reservoirs while topping off.
When the high switch is triggered (aka, finished topping off),
ALL ports are turned off regardless of status (doesn't hurt to do this).
If the timeout occurs, the LED light comes on and all ports are
turned off just like when we finish topping off.
unsigned long TempTimeout = ATOTimeout;
TempTimeout *= 1000;
if ( ReefAngel.LowATO.IsActive() && ( !ReefAngel.LowATO.IsTopping()) )
ReefAngel.LowATO.Timer = millis();
ReefAngel.LowATO.StartTopping();
// Check the level of each reservoir
// If empty, set the alert and don't start topping off
// otherwise if not empty, clear the alert and start topping
CheckReservoirStatus(0, Port5);
CheckReservoirStatus(1, Port6);
CheckReservoirStatus(2, Box1_Port5);
// Monitor levels while topping off, to prevent a reservoir from running dry
// Might need to remove this check here -- Nope, this seems to work fine.
if ( ReefAngel.LowATO.IsTopping() )
if ( ReefAngel.HighATO.IsActive() )
ReefAngel.LowATO.StopTopping(); // stop the low ato timer
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.Off(Box1_Port5);
if ( (millis()-ReefAngel.LowATO.Timer > TempTimeout) && ReefAngel.LowATO.IsTopping() )
ReefAngel.LED.On();
#ifdef ENABLE_EXCEED_FLAGS
InternalMemory.write(ATO_Exceed_Flag, 1);
#endif // ENABLE_EXCEED_FLAGS
#ifdef ENABLE_ATO_LOGGING
// bump the counter if a timeout occurs
AtoEventCount++;
if ( AtoEventCount >= MAX_ATO_LOG_EVENTS ) { AtoEventCount = 0; }
#endif // ENABLE_ATO_LOGGING
loop section:
//If the ATO float switch is stuck, and the topoff pump timeout flag is set, then set C5=1
if ( InternalMemory.read(ATO_Exceed_Flag) == 1 )
ReefAngel.CustomVar[5]=1;
ReefAngel.CustomVar[5]=0;
The following feature was automatically added:
Watchdog Timer
Version Menu
Dimming Signal
I/O Expansion Module
Wifi
Relay Expansion Module
Number of Relay Expasions: 1
Custom Main Screen
Custom Menu
Number of Menu Options: 9
Custom Variable
Exceed Flagging
Extra Font - Large Size (8x16 pixels)
Extra Font - Extra Large Size (12x16 pixels)
Extra Font - Numbers Only - Medium Size (8x8 pixels)
Extra Font - Numbers Only - Large Font (8x16 pixels)
Extra Font - Numbers Only - Extra Large Font (12x16 pixels)
Extra Font - Numbers Only - Huge Font (16x16 pixels)
Date/Time Setup Menu
Binary sketch size: 41,740 bytes (of a 258,048 byte maximum)
Just to be sure, you do have MyCustomATO() inside loop(), correct?
Other than that, everything looks good.
Does the red status led turn on when the you get ato timeout?
Yes, MyCustomATO() is inside loop(), and the red status light comes on. I just retested it all to make sure, too. Here is the (now lengthy) code:
#define SetupExtras
#define VersionMenu
#define wifi
#define RelayExp
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MAIN
#define COLORS_PDE
#define IOEXPANSION
#define FONT_8x8
#define FONT_8x16
#define FONT_12x16
#define NUMBERS_8x8
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long buzzerinterval = 1000; // interval at which to sound buzzer (milliseconds)
long previousMillis = 0;
prog_char menu7_label[] PROGMEM = "Version";
prog_char menu8_label[] PROGMEM = "Turn ON/OFF Skimmer";
prog_char menu9_label[] PROGMEM = "Turn Off Skimmer";
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
void MenuEntry8()
ReefAngel.Relay.Toggle(Box1_Port8);
ReefAngel.Relay.Write();
void MenuEntry9()
ReefAngel.Relay.Off(Box1_Port8);
// draw main relay
#ifdef RelayExp
// draw 1st expansion relay
#endif // RelayExp
// Change the 45 to adjust the horizontal position of the text
void CheckReservoirStatus(byte channel, byte pump)
if ( ReefAngel.IO.GetChannel(channel) )
// If empty, shutoff the port, trigger alert
ReefAngel.CustomVar[channel] = 1;
ReefAngel.Relay.Off(pump);
// If not empty, turn on the port, clear alert
ReefAngel.CustomVar[channel] = 0;
ReefAngel.Relay.On(pump);
start the pump.
ReefAngel.LED.On();
AtoEventCount++;
// Initialize the custom menu
ReefAngel.FeedingModePorts = Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port4Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port2Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port8);
ReefAngel.OverheatProbe = T1_PROBE; // Use Temperature probe 1 to check for overheat
ReefAngel.StandardLights(Port1,23,0,2,0); // Moon lights on 23:00-02:00
ReefAngel.StandardHeater(Port2,780,790); // 800w heater on at 78.0, off at 79.0
ReefAngel.MHLights(Port4); // MH on 14:00-22:00, delay 15m if power fails
ReefAngel.StandardLights(Port7,21,0,13,0); // Sump lights on 21:00-13:00
ReefAngel.MHLights(Box1_Port1); // MH on 14:00-22:00, delay 15m if power fails
ReefAngel.StandardHeater(Box1_Port2); // 250w heater on at 78.5, off at 79.0
ReefAngel.StandardLights(Box1_Port3); // Actinics on 13:00-23:00
//ATO function
MyCustomATO(InternalMemory.ATOTimeout_read());
//Notify when sump level is low
if ( ReefAngel.IO.GetChannel(4) )
ReefAngel.CustomVar[4]=1;
// If the sump level is about to cavitate the pumps, then sound the alarm
if(currentMillis - previousMillis > buzzerinterval) {
// save the last time the buzzer turned on
previousMillis = currentMillis;
// if the buzzer is off turn it on and vice-versa:
if (ReefAngel.PWM.GetDaylightValue() == 0)
ReefAngel.PWM.SetDaylight(25);
// Turn the buzzer off when the sump level is above cavitation levels
ReefAngel.CustomVar[4]=0;
//Vodka dosing
if ( ReefAngel.IO.GetChannel(3) ) //Check there is vodka in the reservoir
ReefAngel.Relay.Off(Box1_Port6); //If no vodka, then set a variable and turn off the port
ReefAngel.CustomVar[3]=1;
else //If there is vodka, then dose
ReefAngel.CustomVar[3]=0;
ReefAngel.DosingPumpRepeat1(Box1_Port6);
ReefAngel.Portal("btorrenga");
How about the other custom variables??
Are they working?
Are they working?
All the other variables are working great. I have been testing them all afternoon and am very pleased.
Try doing this instead to see what values you are getting:
Technically, it should be the same thing, but simplified.
ReefAngel.CustomVar[5]=InternalMemory.read(ATO_Exceed_Flag);
Getting some results now. The values I have seen reported in the portal have been 181, 191, 255 and 255. I am not sure how those numbers are determined, but at least something is happening. I assumed the value of ATO_Exceed_Flag would be 1 or 0 only. How is the value determined?
Weird.
It should be 0 or 1.
This line writes 1 and when you clear ATO timeout, it writes 0.
I would expect that behavior, too. I have cleared the ATO and now ATO_Exceed_Flag is reporting to the portal as 254.
Can you add this to your loop() and open Tools->Serial Monitor and see what you get?
Make sure to set Serial Monitor to use 57600 baud.
Serial.print("CustomVar[5]: ");
Serial.println(InternalMemory.read(ATO_Exceed_Flag));
what is the water level variable? I'd like to see a graph.
