How to use the trigger options in the Portal
Related to the Portal
PostPosted: Sat Jun 02, 2012 7:51 pm
Yes, MyCustomATO() is inside loop(), and the red status light comes on. I just retested it all to make sure, too. Here is the (now lengthy) code:
#define DisplayImages
#define SetupExtras
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define wifi
#define SaveRelayState
#define RelayExp
#define DosingPumpIntervalSetup
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 9
#define CUSTOM_MAIN
#define COLORS_PDE
#define ENABLE_ATO_LOGGING
#define ENABLE_EXCEED_FLAGS
#define IOEXPANSION
#define FONT_8x8
#define FONT_8x16
#define FONT_12x16
#define NUMBERS_8x8
#define NUMBERS_8x16
#define NUMBERS_12x16
#define NUMBERS_16x16
#define CUSTOM_VARIABLES
#include <avr/pgmspace.h>
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long buzzerinterval = 1000;           // interval at which to sound buzzer (milliseconds)
long previousMillis = 0;
prog_char menu7_label[] PROGMEM = "Version";
prog_char menu8_label[] PROGMEM = "Turn ON/OFF Skimmer";
prog_char menu9_label[] PROGMEM = "Turn Off Skimmer";
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
void MenuEntry8()
ReefAngel.Relay.Toggle(Box1_Port8);
ReefAngel.Relay.Write();
void MenuEntry9()
ReefAngel.Relay.Off(Box1_Port8);
  // draw main relay
#ifdef RelayExp
  // draw 1st expansion relay
#endif  // RelayExp
  // Change the 45 to adjust the horizontal position of the text
void CheckReservoirStatus(byte channel, byte pump)
    if ( ReefAngel.IO.GetChannel(channel) )
        // If empty, shutoff the port, trigger alert
        ReefAngel.CustomVar[channel] = 1;
        ReefAngel.Relay.Off(pump);
        // If not empty, turn on the port, clear alert
        ReefAngel.CustomVar[channel] = 0;
        ReefAngel.Relay.On(pump);
void MyCustomATO(int ATOTimeout)
    This function works as follows:
    When it's time to topoff the system, we check the levels of each
    of the three reservoirs.  If a reservoir is empty, we set a custom
    flag to indicate it's empty on the portal and we do not start that
    pump.  Otherwise, we clear the custom flag for the reservoir and
    start the pump.
    The function monitors the switch levels like normal.
    Monitor the status of the reservoirs while topping off.
    When the high switch is triggered (aka, finished topping off),
    ALL ports are turned off regardless of status (doesn't hurt to do this).
    If the timeout occurs, the LED light comes on and all ports are
    turned off just like when we finish topping off.
    unsigned long TempTimeout = ATOTimeout;
    TempTimeout *= 1000;
    if ( ReefAngel.LowATO.IsActive() && ( !ReefAngel.LowATO.IsTopping()) )
        ReefAngel.LowATO.Timer = millis();
        ReefAngel.LowATO.StartTopping();
        // Check the level of each reservoir
        // If empty, set the alert and don't start topping off
        // otherwise if not empty, clear the alert and start topping
        CheckReservoirStatus(0, Port5);
        CheckReservoirStatus(1, Port6);
        CheckReservoirStatus(2, Box1_Port5);
    // Monitor levels while topping off, to prevent a reservoir from running dry
    // Might need to remove this check here -- Nope, this seems to work fine.
    if ( ReefAngel.LowATO.IsTopping() )
    if ( ReefAngel.HighATO.IsActive() )
        ReefAngel.LowATO.StopTopping();  // stop the low ato timer
        ReefAngel.Relay.Off(Port5);
        ReefAngel.Relay.Off(Port6);
        ReefAngel.Relay.Off(Box1_Port5);
    if ( (millis()-ReefAngel.LowATO.Timer > TempTimeout) && ReefAngel.LowATO.IsTopping() )
        ReefAngel.LED.On();
#ifdef ENABLE_EXCEED_FLAGS
        InternalMemory.write(ATO_Exceed_Flag, 1);
#endif  // ENABLE_EXCEED_FLAGS
#ifdef ENABLE_ATO_LOGGING
        // bump the counter if a timeout occurs
        AtoEventCount++;
        if ( AtoEventCount >= MAX_ATO_LOG_EVENTS ) { AtoEventCount = 0; }
#endif  // ENABLE_ATO_LOGGING
    // Initialize the custom menu
    ReefAngel.FeedingModePorts = Port8Bit;
    ReefAngel.FeedingModePortsE[0] = Port4Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit | Port3Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port2Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port8);
    ReefAngel.OverheatProbe = T1_PROBE; // Use Temperature probe 1 to check for overheat
    ReefAngel.StandardLights(Port1,23,0,2,0); // Moon lights on 23:00-02:00
    ReefAngel.StandardHeater(Port2,780,790); // 800w heater on at 78.0, off at 79.0
    ReefAngel.MHLights(Port4); // MH on 14:00-22:00, delay 15m if power fails
    ReefAngel.StandardLights(Port7,21,0,13,0); // Sump lights on 21:00-13:00
    ReefAngel.MHLights(Box1_Port1); // MH on 14:00-22:00, delay 15m if power fails
    ReefAngel.StandardHeater(Box1_Port2); // 250w heater on at 78.5, off at 79.0
    ReefAngel.StandardLights(Box1_Port3); // Actinics on 13:00-23:00
    //ATO function
    MyCustomATO(InternalMemory.ATOTimeout_read());
    //Notify when sump level is low
    if ( ReefAngel.IO.GetChannel(4) )
      ReefAngel.CustomVar[4]=1;
        // If the sump level is about to cavitate the pumps, then sound the alarm
        if(currentMillis - previousMillis > buzzerinterval) {
    // save the last time the buzzer turned on
    previousMillis = currentMillis;
    // if the buzzer is off turn it on and vice-versa:
    if (ReefAngel.PWM.GetDaylightValue() == 0)
      ReefAngel.PWM.SetDaylight(25);
      ReefAngel.PWM.SetDaylight(0);
        // Turn the buzzer off when the sump level is above cavitation levels
        ReefAngel.CustomVar[4]=0;
//If the ATO float switch is stuck, and the topoff pump timeout flag is set, then set C5=1
if ( InternalMemory.read(ATO_Exceed_Flag) == 1 )
ReefAngel.CustomVar[5]=1;
ReefAngel.CustomVar[5]=0;
//Vodka dosing
      if ( ReefAngel.IO.GetChannel(3) )  //Check there is vodka in the reservoir
    ReefAngel.Relay.Off(Box1_Port6);  //If no vodka, then set a variable and turn off the port
    ReefAngel.CustomVar[3]=1;
  else  //If there is vodka, then dose
    ReefAngel.CustomVar[3]=0;
    ReefAngel.DosingPumpRepeat1(Box1_Port6);
    ReefAngel.Portal("btorrenga");
PostPosted: Sat Jun 02, 2012 7:53 pm
How about the other custom variables??
Are they working?
PostPosted: Sat Jun 02, 2012 7:55 pm
All the other variables are working great. I have been testing them all afternoon and am very pleased.
PostPosted: Sat Jun 02, 2012 7:59 pm
Try doing this instead to see what values you are getting:
ReefAngel.CustomVar[5]=InternalMemory.read(ATO_Exceed_Flag);
Technically, it should be the same thing, but simplified.
PostPosted: Sat Jun 02, 2012 8:36 pm
Getting some results now. The values I have seen reported in the portal have been 181, 191, 255 and 255. I am not sure how those numbers are determined, but at least something is happening. I assumed the value of ATO_Exceed_Flag would be 1 or 0 only. How is the value determined?
PostPosted: Sat Jun 02, 2012 8:41 pm
Weird.
It should be 0 or 1.
This line writes 1 and when you clear ATO timeout, it writes 0.
PostPosted: Sat Jun 02, 2012 8:46 pm
I would expect that behavior, too. I have cleared the ATO and now ATO_Exceed_Flag is reporting to the portal as 254.
PostPosted: Mon Jun 04, 2012 3:17 pm
Can you add this to your loop() and open Tools->Serial Monitor and see what you get?
Serial.print("CustomVar[5]: ");
Serial.println(InternalMemory.read(ATO_Exceed_Flag));
Make sure to set Serial Monitor to use 57600 baud.
PostPosted: Mon Sep 24, 2012 10:12 pm
what is the water level variable? I'd like to see a graph.
PostPosted: Mon Sep 24, 2012 10:17 pm
I update the list.
Return to Portal
