Hey guys,
I just updated my libraries to version 0.9. Everything seems to work fine on the web portal except I can't seem to get the web chart to work. When I click on web chart it just comes up blank. I am using Safari and Google Chrome as my web browsers in Mac OSX.
Problem with Web Chart
Re: Problem with Web Chart
To get the data and relay charts to work you need to make sure that your code is structured as follows.
CODE: SELECT ALL
// Specific functions
ReefAngel.StandardFan(Port4);
ReefAngel.Wavemaker1(Port5);
ReefAngel.StandardLights(Port7);
ReefAngel.MHLights(Port8);
// Place your custom code below
// Place your custom code above
ReefAngel.Portal("username", "key");
Your code must before the line... ReefAngel.Portal("username", "key");
Hope that helps.
CODE: SELECT ALL
Hope that helps.
I just checked and I don't see any data that was sent to the portal with your username id jallan258.
If you did not setup the security key in the portal, you should use:
ReefAngel.Portal("jallan258");
Ok guys still not working. I am sure I am doing something stupid so here is my code.
// Autogenerated file by RAGen (v1.2.1.158), (02/20/2012 11:34)
// RA_022012_1134.ino
#define DisplayImages
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
ReefAngel.FeedingModePorts = Port4Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port5Bit | Port6Bit;
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port8);
ReefAngel.StandardATO(Port1);
//Refugum Light/Moon Lights
// LED Fans
ReefAngel.StandardLights(3,10,30,19,30);
// Specific Programing for PWM Slope Drivers Actinic Port
ReefAngel.StandardLights(5,10,30,19,30);
// Specific Programming for PWM Slope Drivers Daylight Port
ReefAngel.StandardLights(6,11,30,18,30);
// PWM Slope in following format (hour on, minute on, hour off, minute off, Low Value Dim, High Value Dim, Time to reach Dim)
// Calculate your regular sunrise/sunset PWM value
ActinicPWMValue=PWMSlope(10,30,19,30,13,100,60,ActinicPWMValue);
DaylightPWMValue=PWMSlope(11,30,18,30,13,100,60,DaylightPWMValue);
CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
#define Min_Cloud_Duration 15
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(17,30)
#define Lightning_Change_per_Cloud 35
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
//Changed Lightning to 40 seconds
//Added this entire Reverse Slope
ActinicPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,13,180);
if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<40)
else lightningstatus=0;
if (lightningstatus)
//Changed Actinic Value to 13
DaylightPWMValue=100;
ActinicPWMValue=13;
DaylightPWMValue=0;
ActinicPWMValue=13;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if ((cloudstart/60)>=10) x=11; else x=17;
if ((cloudstart%60)>=10) x=29; else x=35;
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
Everything looks good.
When you setup your wifi attachment, did you go through the remote settings too?
They are the last steps.
http://forum.reefangel.com/viewtopic.php?f=15&t=345
It looks like that was the problem. Everything is working great again thanks guys.
