Custom Web Chart
Re: Custom Web Chart
Is there a way to graph two or more filters on the custom web chart. Such as filter=T1,WL. If not, can this be added?
No...
You would have to copy the javascript source code and create your own html page.
Because it is jsonp based, it doesn't really need to be hosted in the server.
Has anyone attempted this javascript? I'm playing with my dimming strategy and it would be really useful to overlay my pwm channels and see when each is dimming and coming on, etc.
Roberto, aren't you already doing this with the two graphs already built into the portal? Couldn't you give us a way load more than one param? Or can you point us to the code your using to map the Temps/PH or the relay status?
Thanks in advance
Thanks in advance
I created a page for the new U-App that should work for your purpose:
http://forum.reefangel.com/status/appch ... &filter=t2
You can just append filters.
Works well but strange because of the not graphing 0s...i might have to adjust my code to shut off at 1% so there's something to graph..
- jsclownfish
I don't know if it helps, but Roberto made this example for me awhile ago and I keep icons on my phone and iPad that quickly bring up an assortment of graphs. http://forum.reefangel.com/viewtopic.ph ... lit=+chart It's nice to use when I just want a quick look at the flow rates, or lighting sensors, I am using.
-Jon
-Jon
Yes, the server doesn't store zeros.lnevo wrote:Works well but strange because of the not graphing 0s...i might have to adjust my code to shut off at 1% so there's something to graph..
The server doesn't have to store zeroes if you filled in the gaps though it would suffice
If your missing data just fill in the missing timestamps with 0...so if at 6am i had 5 and that was the last data, but I'm getting the chart at 7am, we can fill in 0 at 6:05, 6:10, 6:15... We can just assume no data sent would also be 0..good for if controller goes offline and you look at a chart today you will think your WL is just fine since the chart shows 50%...meanwhile your not sending data for 3 days...for example.
It also hides when sensors eroneously report 0...like my ph does occasionally...however i cam see when without finding a gap in the timeline..
We would need to analyze the results of the query record by record to be able to do this.
Remember that this is a SQL query.
So how about just biting the bullet then and storing 0 values? You could use NULL value for storing non-sent data.
Your using HighCharts IIRC? I think they have some solutions and its actually opposite of what I said above if I'm interpreting correctly. It asks for you to store the missing data as NULL if you want the x axis to stay consistent.
For missing data on HighCharts, here is an example of making the X axis of the chart nice and even which might be uneven in time (Because of 0 values or missed contact with the controller).
http://www.highcharts.com/demo/spline-irregular-time
I don't see what they're doing different from what the portal does in its JS code, though. Maybe it's a later version of the .js than what the portal points to?
Looks like if the data is a series of x,y values, or I assume an array of 2 element arrays. it should do the right thing with the datetime plot.
That seems to be the same way I setup the charts
<!DOCTYPE HTML>
<html>
<head>
<meta charset="utf-8" />
<meta name="format-detection" content="telephone=no" />
<!-- WARNING: for iOS 7, remove the width=device-width and height=device-height attributes. See https://issues.apache.org/jira/browse/CB-4323 -->
<meta name="viewport" content="user-scalable=no, initial-scale=.5, maximum-scale=.5, minimum-scale=.5, target-densitydpi=device-dpi" />
<meta name="msapplication-tap-highlight" content="no" />
<link href='http://code.jquery.com/mobile/1.3.2/jquery.mobile-1.3.2.min.css' rel='stylesheet'>
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.6.2/jquery.min.js"></script>
<script src='http://code.jquery.com/mobile/1.3.2/jquery.mobile-1.3.2.min.js'></script>
<title>Reef Angel U-App</title>
<script type="text/javascript">
$(function () {
$.mobile.loading( 'show', {
text: 'Connecting to Portal',
textVisible: true,
theme: 'b',
html: ""
Highcharts.setOptions({
global: {
useUTC: false
var seriesOptions = [],
yAxisOptions = [],
seriesCounter = 0,
seriesID = 0,
names = [
'PH'
colors = Highcharts.getOptions().colors;
$.each(names, function (i, name) {
$.getJSON('http://forum.reefangel.com/status/jsonp.aspx?id=reefangel&filter=' + name.toLowerCase() + '&callback=?', function (data) {
var pcolor;
var tname;
var ydec;
var yunit;
if (name == "PH") {
pcolor = '#669900'
tname = 'pH'
ydec = 2
yunit = 'pH'
else if (name == "PHE") {
pcolor = '#447700'
tname = 'pH Expansion'
ydec = 2
yunit = 'pH'
else if (name == "SAL") {
pcolor = '#000066'
tname = 'Salinity'
ydec = 1
yunit = 'ppt'
else if (name == "ORP") {
pcolor = '#330000'
tname = 'ORP'
ydec = 0
yunit = 'mV'
else if (name == "T1") {
pcolor = '#FF0000'
tname = 'Temp 1'
ydec = 1
yunit = '°'
else if (name == "T2") {
pcolor = '#FF8800'
tname = 'Temp 2'
ydec = 1
yunit = '°'
else if (name == "T3") {
pcolor = '#9900CC'
tname = 'Temp 3'
ydec = 1
yunit = '°'
else {
pcolor = '#FF0000'
tname = 'PH'
ydec = 0
yunit = ''
if (data.length) {
seriesOptions[seriesID] = {
dataGrouping: {
smoothed: true
color: pcolor,
tooltip: {
yDecimals: ydec,
ySuffix: yunit
data: data
seriesID++;
// As we're loading the data asynchronously, we don't know what order it will arrive. So
// we keep a counter and create the chart when all the data is loaded.
seriesCounter++;
if(data.length==0)
$('#container').html("No data to display");
$.mobile.loading( "hide" );
if (seriesCounter == names.length) {
createChart();
// create the chart when all data is loaded
function createChart() {
chart = new Highcharts.StockChart({
chart: {
renderTo: 'container',
type: 'spline'
title: {
text: 'Reef Angel Controller Web Chart'
subtitle: {
text: 'Parameters logged for the past 7 days'
credits: {
enabled: false
legend: {
enabled: true,
//align: 'right',
//backgroundColor: '#FCFFC5',
borderColor: 'black',
borderWidth: 2,
//layout: 'vertical',
verticalAlign: 'top',
y: 100,
shadow: true
rangeSelector: {
buttons: [{
type: 'minute',
count: 60,
text: '1h'
type: 'minute',
count: 720,
text: '12h'
type: 'day',
count: 1,
text: '1d'
type: 'day',
count: 3,
text: '3d'
type: 'all',
text: '7d'
selected: 2,
inputEnabled: false
navigator: {
xAxis: {
type: 'datetime',
maxZoom: 3600000, // 1 hour
dateTimeLabelFormats: { // don't display the dummy year
second: '%I:%M:%S %p',
minute: '%I:%M %p',
hour: '%b/%e',
day: '%b/%e',
week: '%b/%e'
xAxis: {
type: 'datetime',
minute: '%I:%M %p',
hour: '%I:%M %p',
day: '%b/%e',
week: '%b/%e'
yAxis: {
plotLines: [{
value: 0,
width: 1,
color: 'silver'
tooltip: {
borderColor: 'silver',
xDateFormat: '%A, %b %e, %l:%M %p',
pointFormat: '<span style="color:{series.color}">{series.name}</span>: <b>{point.y}</b><br/>'
series: seriesOptions
</script>
</head>
<body>
<script type="text/javascript" src="http://forum.reefangel.com/js/highstock.js"></script>
<div id="container" style="height: 500px; min-width: 600px"></div>
</body>
</html>
Right. Is it because you use highstock.js instead of highchart.js? I wouldn't think so, though. Weird.
When using this with the pwm channels it uses the same color coding for both channels. Is there a way to change that?rimai wrote:I created a page for the new U-App that should work for your purpose:
Thanks, that looks better. The only weird thing (minor) is that on the legend it puts both, pwma & pwmd, for each line. It doesn't do this for temperature.rimai wrote:I changed it so it uses a random color.
Try it again.
It's fixed, thanks again. Really like my RA equipment and appreciate all you support Roberto.rimai wrote:It's a bug. Thanks for reporting.
I fixed it. Try again.
Wow, the random colors is awesome. Roberto, the only thing this doesn't do that the other web chart does is the link to download link and print (not so usefull...) Can you add the export option to this one? And at that point, does it makes sense to not just combine them to one?
I'll change the other one with the same capability, but with the export added to it.
Awesome, I hated having to use screengrab to download the graph
Just wanted to say the new charts have been great! And the database fix has been awesome! They load so quick now!!!
Quick question. How do you pull in data for a relay? Like can i map my heater port R6 with T1?
Whats the issue? You do it for the relay data chart already...
