Questions about Reef Angel Portal?
Hi,
i have some questions:
- in the live version, How many every minutes the Portal contact my RA ?
- if i want to use the live version, can set the wifi password to my RA ?
Bye
Bye
Re: Questions about Reef Angel Portal?
first question . ok !
i see that the portal retrive the information automatically
Password protection on the wifi module will not work with the Portal. None of the apps work with the wifi authentication currently.
do you think is possible add these feature ?
Yes, it is. We've had problems with the apps working properly with the wifi authentication and have not focused on getting them to work.lukeluke wrote:do you think is possible add these feature ?
ok thanks.
is very risky to leave open the web server... i had some problems...
I agree. It all looks good, but leaving it open on the web is just too dangerous.
I was almost ready to give it a try and was looking specifically for security for controller. Knowing that almost anyone can mess it up....
Even at home with App installed on iPad over local network I would like to have some code to be entered before application can change anything. Why? Do you have friend with kids? Sometimes they play on iPad while adults are talking. You never know what kids can do.
I think password for controller is a must. All these remote features without security are more evil then good.
Am I too paranoid or no one else see this as a problem?
Good point.
You can also change the standard port 2000 to any other port.
I need to dig up why the authentication is failing on the apps.
quote serhiyi.
for me is very important the auth
the port is not a workaround a simple child with network scanner find it
Regarding that first dashboard that comes up? Is this changeable to one of the prettier, colorful ones? Thx
this is what I see when I start my portal:
- sample of my portal
- dashboard.png (110.57 KiB) Viewed 5513 times
I would prefer one of the banner displays (like my sig) but if this is the default, it is fine. I just wanted to make sure if it was changeable that I knew how to do it. Thx
Seems paranoid. Will be nice to get it working but I doubt fish tanks are very high on hackers priority list.
Also I think the opening screen is great. You should see some of the GUIs I use on multimillion dollar robots.
Function first, pretty last.
I want enable the portal database.
On my RA i insert:
Reefangel.portal(lukeluke);
On the portal web settings, i must insert ”lukeluke” ? Or not ? Or only the key ?
Tnx
On my RA i insert:
Tnx
You need to use it like this in your code:
Reefangel.Portal("lukeluke");
ok, this in my code .ino
but the string in the web portal ?
Tnx
Tnx
Are you talking about the security key?
If youplace a security key on the portal settings, you need to change your code too.
Let's say you enter "mykey" on the security key field.
Yuo code will need to be changed to:
ReefAngel.Portal("lukeluke","key");
Hi Luca,
I was testing the custom fields and was unable to get it to send email notifications too.
Let me check what is going on.
why if i remove the live url, the database portal don't work ?
this is the config of my RA wifi box:
IF=UP
DHCP=OFF
IP=192.168.1.3:2000
NM=255.255.255.0
GW=192.168.1.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1460
FLAGS=0x7
BACKUP=0.0.0.0
<2.21> get w
SSID=Casa
Chan=0
ExtAnt=0
Join=1
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=xxxxxxxxxxxxxxxxxx
<2.21>
My string in .ino sketch is:
ReefAngel.Portal("lukeluke");
The Portal settings is :
Portal() security key: 0
wich is the problem ?
TNX
IF=UP
DHCP=OFF
IP=192.168.1.3:2000
NM=255.255.255.0
GW=192.168.1.1
PROTO=TCP,
MTU=1460
FLAGS=0x7
BACKUP=0.0.0.0
<2.21> get w
SSID=Casa
Chan=0
ExtAnt=0
Join=1
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
<2.21>
TNX
I'm assuming you used Dave's graphical wifi utility to set it up, right?
Did you setup the remote settings part too?
i don't love gui i set it trought your pdf guide by CLI
i get the value in telnet on my RA wifi box.
if you want, you can enter macking telnet on my live url set in the portal.
do you see some errors ?
Try these commands:
set u m 2
set d n www.reefangel.com
set i h 198.171.134.6
set i r 80
save
reboot
set u m 2
set i r 80
save
reboot
i try to do your commands...but nothing.
this is the debug of RA Wifi Box:
<2.21> get eve
WiFly Ver 2.21, 07-11-2010
Beacon=100
Probe=60
OPEN=
CLOSE=
REMOTE=
FlushSize=1024
MatchChar=0
FlushTimer=10
IdleTimer=3
CmdChar=$
IF=UP
DHCP=OFF
IP=192.168.1.3:2000
NM=255.255.255.0
GW=192.168.1.1
PROTO=TCP,
MTU=1460
FLAGS=0x7
BACKUP=0.0.0.0
DNS=192.168.1.1
Name=www.reefangel.com
Backup=backup2
FTP=208.109.78.34:21
File=wifly-GSX.img
User=roving
Pass=Pass123
SSID=Casa
Chan=0
ExtAnt=0
Join=1
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=xxxxxx
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
PrintLvl=0x0
TimeEna=0
TIMEADR=129.6.15.28:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
JoinTmr=1000
Replace=0x24
DeviceId=WiFly-GSX
Password=
Format=0x0
Sensors=0x0
BCAST=255.255.255.255:55555
Interval=0x7
<2.21>
what can i do ?
<2.21> get eve
Beacon=100
Probe=60
OPEN=
CLOSE=
REMOTE=
FlushSize=1024
MatchChar=0
FlushTimer=10
IdleTimer=3
CmdChar=$
IF=UP
DHCP=OFF
IP=192.168.1.3:2000
NM=255.255.255.0
GW=192.168.1.1
PROTO=TCP,
MTU=1460
FLAGS=0x7
BACKUP=0.0.0.0
DNS=192.168.1.1
Backup=backup2
File=wifly-GSX.img
User=roving
Pass=Pass123
SSID=Casa
Chan=0
ExtAnt=0
Join=1
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=xxxxxx
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
PrintLvl=0x0
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
JoinTmr=1000
Replace=0x24
DeviceId=WiFly-GSX
Password=
Format=0x0
Sensors=0x0
Interval=0x7
<2.21>
what can i do ?
Everything seems correct.
Are you sure your 192.168.1.1 gateway is setup to be DNS server?
Yes, is correct.rimai wrote:Everything seems correct.
This is the ip of the router adsl, that make also the dns service.
I think the problem is that you have the security key on.
Go to portal settings and turn it off.
I'm stupid !!!
i put it off and now work right !
