Can use Portal with older dev libraries?
Related to the Portal
pepsiman
Post by pepsiman »
I just finally spent the past 2 weeks setting up my Reef Angel, and now everything is working perfectly.
I am using the older libraries 0.8xx and was wodnering if theres a way I can use the portal with it...
I dont want to re-install and change everything, because I spent quite some time making everything working.
Re: Can use Portal with older dev libraries?
You will be able to have limited usage by using the old WebBanner() function.
