Reef Portal connection
To use the Reef Portal I will assume you need the wifi adapter. Do you require a computer to always be on or does the controller update the portal?
Re: Reef Portal connection
The controller can update the controller for you automatically.
Make sure you use the same ports for external and internal.
It's best to open just port 2000, so you should have 2000-2000 on both external and internal
Hi, I cant get the portal running. This is what I did:
- Configured the .ino file vía RAgen with line ReefAngel.Portal("danielsn","xxx")
- Set the Reef Angel Wifi Address: BLANK
- Try (I´m not sure if this part is OK) to "port forward" my router as in the pic:
Any help will be appreciated
Thanks!!
Thanks!!
- Router.jpg (62.22 KiB) Viewed 8048 times
I've seen before where the server failed to collect the ip address for some reason and I was unable to find out why. I actually didn't have time to investigaste further.
Does the Portal show up your Reef Angel wifi address correctly? It should be at the top right corner and it should show your wan ip address.
You can find your wan ip address at www.whatismyip.com
Hi Roberto,
The portal shows:
Reef Angel wifi address: (update)
My reefangelid: danielsn
Connection Status: Unreachable Address
Last Update: viernes, 06 de abril de 2012 16:35:42
Displaying data from: Webbanner database
The IP is different every time: 190.30.50.156 ... 181.1.173.108 ... etc
The portal shows:
I can't see any data coming from you on the server.
Can you make sure you did upload a code with the Portal() function in your code?
Hi Roberto, this is what I haveat the end:
ReefAngel.Portal("danielsn", "xxx");
Thanks for your help
If you have that, it can only be the wifi attachment missing some setting.
When you setup your wifi attachment, did you use the same application on this thread?
http://forum.reefangel.com/viewtopic.php?f=15&t=345
Yes, I used that , but the the wifi only works if the Security Mode on the router is disabled . Do you think that this could be related?
Does the utility give you an ip address?
What happens when you browse to that ip address?
It should be something like this:
http://192.168.0.100:2000
Hi Roberto, which utility are you talking about?
It should have given you an ip address.
The IP given is 192.168.2.3:2000
When I put it on the browser it shows the "Reef Angel Controller Web Server" legend, and adding /wifi I get the parameter readings. This is working ok, and also the Client, I can see the graphs and the paramaters.
The only thing that is not working is the Portal (and teh fact thta the Security Mode of the router has to be "disabled" to make this things work)
I'm curious to know what mode it says on the utility.
Can you find that out?
It's the line just above the ip address.
The Mode is not shown:
- WIFI6-4-12.jpg (41.49 KiB) Viewed 3066 times
