If you have that, it can only be the wifi attachment missing some setting.
When you setup your wifi attachment, did you use the same application on this thread?
http://forum.reefangel.com/viewtopic.php?f=15&t=345
Reef Portal connection
Re: Reef Portal connection
Yes, I used that , but the the wifi only works if the Security Mode on the router is disabled . Do you think that this could be related?
Does the utility give you an ip address?
What happens when you browse to that ip address?
It should be something like this:
http://192.168.0.100:2000
Hi Roberto, which utility are you talking about?
It should have given you an ip address.
The IP given is 192.168.2.3:2000
When I put it on the browser it shows the "Reef Angel Controller Web Server" legend, and adding /wifi I get the parameter readings. This is working ok, and also the Client, I can see the graphs and the paramaters.
The only thing that is not working is the Portal (and teh fact thta the Security Mode of the router has to be "disabled" to make this things work)
I'm curious to know what mode it says on the utility.
Can you find that out?
It's the line just above the ip address.
The Mode is not shown:
- WIFI6-4-12.jpg (41.49 KiB) Viewed 3065 times
