Hi
It will be nice if you can put a scale adjuster for the web chart feature in the portal, this way we can see a lot better what is happening in tank and the relation with parameters, cause the charts have big scales between 10-30, but my temp is always between 25-28 the rest is just empty space same for ph.
scale adjuster for web chart
Re: scale adjuster for web chart
You are talking about Y scale right?
If so, that feature is not available.
I auto scales as you hide/unhide each parameter, but it will take the 0 as the the bottom
Let me see if I can get around some...
I should have looked before replied.
Right after I did, I remember when I was setting up I placed a 0 for the min Y setting.
I removed that setting and voila!!
Check it out now. As you remove the parameters, it auto scales to min/max of the parameters that are showing. Pretty neat
Maybe i'm doing something wrong or have to change some setting but this is what i'm getting:
You have to hide the pH. Click on the label to hide/unhide
- jsclownfish
Nice, thanks
Hello
Same thing on the iPhone app?
Thx
Thx
Fresh Water Aquarium 180*60*80
Salt Water Aquarium 60*60*60
