Water Level ATO programming issue
PostPosted: Sat Jun 17, 2017 4:43 pm
Maybe I don't understand the parameters set with the Water Level sensor using as an ATO. It appears that at least sometimes, the only way I'm able to engage the low level is to clear ATO Timeout (no "timeout has occurred). I'm assuming low level should engage (start filling) when my low level percentage is reached and when my high level percentage is reaached, it should shut-off the relay. I watch the Uapp screen for the levels, and it doesn't engage/disengage when my numbers are reached. However, I've let it go for a few hours, and it must have run as my level has remained pretty constant. I've now connected to my kalk stirrer so I need a way to set a very short interval I can depend on and follow visually so I started with 97 high and 94 low. My level got down to 92-93, I cleared the ATO, and the pump came right on. This has occurred other times as well, though like I said, it must not always be occurring or the controller isn't really using the high/low values I've entered into Uapp. This is my code:
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.AddMultiChannelWaterLevelExpansion();  // Multi-Channel Water Level Expanion Module
    ReefAngel.FeedingModePorts = Port7Bit;
    ReefAngel.FeedingModePortsE[0] = Port3Bit;
    ReefAngel.WaterChangePorts = Port4Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit;
    //*ReefAngel.Relay.On( Port1 ); - place holder for Webwizard.  Using ActinicLights code for Port 1
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardLights( Port2 );
    ReefAngel.StandardHeater1( Box1_Port2 );
    ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port2 ) );
    ReefAngel.StandardHeater1( Port5 );
    ReefAngel.WaterLevelATO( 1,Port8 );
    ///if ( ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port8); - Not yet installed
    ReefAngel.Relay.DelayedOn( Port7 );
    ReefAngel.StandardFan1( Port6 );
    if ( ReefAngel.Params.PH > 840 ) ReefAngel.Relay.Off( Port8 );
    ///if ( ReefAngel.LowATO.IsActive()) ReefAngel.Relay.On(Port8); - Not yet installed
    ReefAngel.WaterLevelATO( 2,Box1_Port4,5,95,14400 ); // hard codes ATO reservoir settings since only one available in Uapp.
    MyOwnStandardLights(Port1,-InternalMemory.ActinicOffset_read());  // Calls my new offset to allow negative offset.
    ReefAngel.CloudPortal();
    void MyOwnStandardLights(byte Relay, int MinuteOffset)
   int onTime=NumMins(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read())-MinuteOffset;
   int offTime=NumMins(InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read())+MinuteOffset;
   ReefAngel.StandardLights(Relay,
         onTime/60,
         onTime%60,
         offTime/60,
         offTime%60
// RA_STRING1=U2FsdGVkX1/MRai+5HT5Qq9ZfbEK1mzFXKwT07B7oyM=
// RA_STRING2=U2FsdGVkX1+PuVSO4WlfFCjqa//mhJqdV9c4vId+V1I=
// RA_STRING3=Chloe's House-2.4
PostPosted: Sun Jun 18, 2017 3:03 pm
I think it is because you are using ATO function on two ports and one is affecting the other because one is causing the ATO timeout and the other can't activate because it has the flag on.
I would suggest using only one ATO function.
PostPosted: Tue Jun 20, 2017 9:32 pm
rimai wrote:I think it is because you are using ATO function on two ports and one is affecting the other because one is causing the ATO timeout and the other can't activate because it has the flag on.
I changed that and reloaded, and all is well. What I originally planned with my reservoir wasn't going to work anyway.
Return to Addons
