BUS lock mitigation?
PostPosted: Thu Apr 19, 2018 1:53 pm
Would filling the USB ports with dielectric grease help mitigate issues with corrosion causing bus locking? Haven't thought through the marine/reef safe issues but it seems like a simple preventative option.
PostPosted: Thu Apr 19, 2018 2:18 pm
Additionally spraying the pcb's with a protective coating (like a spray urethane/varnish) to protect from internal corrosion.
Roberto - after all the years of Bus lock issues are the common trends connections and corrosion or does it ever boil down to hardware issues (component tolerances or failures)?
PostPosted: Thu Apr 19, 2018 2:39 pm
It seems to be a resistance issue caused by corrosion.
PostPosted: Fri Apr 20, 2018 4:03 am
So in the scenario where a dimmer expansion is causing bus locks, looking into the schematic there is a 10k pair of pullup resistors on the bus, plus 2.2k's on the expansion hub. If the module is causing a bus lock options are 1. determine the source of corrosion adding to the bus resistance ( ie 10k + 2.2k + unknown corrosion source) and clean it. Or 2. Change the 10k's for something like 8.2k or 7.5k to provide a little extra resistance buffer? Are there any major design concerns with this approach? I see the cable lengths are another variable (capacitance on the bus) which can influence the bus stability. I am interested in your bus watchdog circuit you implemented in the Star series.
NOTALINK//electronics.stackexchange.NOTALINK//questions/1849/is-there-a-correct-resistance-value-for-i2c-pull-up-resistors
NOTALINK//www.ti.NOTALINK//lit/an/slva689/slva689.pdf
PostPosted: Fri Apr 20, 2018 4:12 am
Also would shielding the cables could help from spurious noise on longer cables? (poor man's solution would be wrapping tun foil around the cable as a test)
PostPosted: Fri Apr 20, 2018 9:07 am
Yes, the cable length and the resistance from corrosion are two things to watch for.
PostPosted: Wed Jan 23, 2019 11:41 am
Anyone come across a good solution for preventing corrosion from occurring on the usb headers and connectors?
PostPosted: Sat May 04, 2019 6:14 pm
The 10k resistors are I2C pull-up resistors. 10k is shown on the datasheet for the I2C level shifter that the RA uses, but it's probably too high. Search for TI's "Application Report SLVA689: I2C Bus Pullup Resistor Calculation." (I can't post links.) Lower values give a stronger signal, at the expense of a little bit of current. The minimum is a little bit below 2k. It's the capacitance that's an issue. It takes some current to bring the entire bus back up to 5V, and a 10k resistor just doesn't pass enough. If you add some extra pull-up resistors you may see improvement. It doesn't really matter where the pull-up resistors are located.
(The actual resistance of the cable "shouldn't" be a problem. That just causes a constant voltage drop across the cable; I2C is designed to work between devices running at different voltages, so that should be OK. The I2C spec is more concerned about the bus capacitance.)
Return to Addons
