I am planning to use pwm fanswith the help of pwm expansion module which i will be getting soon
I will try to use 1 fan to check the temp of led heatsink & other one to control the temp of tank as i m living at place where peak summer temp touches 40 degrees & u cant control the heat with chiller too.
Anyone using pwm fans wats the performance of fan with Angel?
