Problem With WiFi.
Re: Problem With WiFi.
192.
I'm not so sure where the 10. came from if your network is setup to 192.
192 series is the IP assigned to devices where as 10 series IP are Dynamic IP provided by ISP
Finally somehow able to forward the port. Portal & client is working fine.
Thanks roberto & others for their support & patience.
prob has started again but this time i am able to use client suite but data on portal is not updating.
What version of the libraries are you using?abhi_123 wrote:prob has started again but this time i am able to use client suite but data on portal is not updating.
Did your ip address assigned to you by your isp change?
If it changes, you will need ddns
rimai wrote:Did your ip address assigned to you by your isp change?
Yep it changes. It's a dynamic IP. The prob looks like to be solved for now. Will see for ddns if its continue.
Looks like the prob is sorted completely. Btw here is a link of site which i used for port forwarding quite simple & free too. www.simpleportforwarding.com
Thanks for sharing.
I liked this application a lot, except for the part I had to find which router model I had... lol...
But it was very easy to get it to setup my router.
rimai wrote:Thanks for sharing.
Any time Roberto.
