how often to replace ph probe
psyrob
Post by psyrob »
Like the title says...how often do and of you replace the ph probe...or just recalibrate over and over? :roll:
Re: how often to replace ph probe
Some replace every year, some never.
It depends on how accurate and whether or not you maintain it.
Are you getting wrong values?
psyrob
Post by psyrob »
Well, the readings have been drifting higher over the past month or so and I haven't been doing anything different in the tank (dosing is all the same, water changes all the same)...and when I inadvertently pushed the ph calibration button on the controller, it showed that ph of 7 was 625 and ph of 10 was 655...those numbers seemed too close together...
If you go to pH calibration, it won't show the previous calibration numbers.
To find out what the previous calibration number are, you need to use any app that can read internal memory: Java Status, Client or Android Phone.
billybob
Post by billybob »
rimai wrote:Some replace every year, some never.
I've been wondering about this. How do we maintain a pH probe, and how often do we need to do it?
I usually place mine on white vinegar to remove anything that grew encrusting the bulb every now and then.
billybob
Post by billybob »
do you recalibrate afterwards?
Not really :(
But I'm not really looking at very precise readings either.
