Ok, I swapped expansion ports 3 with 4, and swapped expansion ports 7 with 8, so that now feeding mode should turn off/on expansion ports 3 and 8:
#define DisplayImages
#define SetupExtras
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define wifi
#define SaveRelayState
#define RelayExp
#define DosingPumpIntervalSetup
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 9
#define CUSTOM_MAIN
#define COLORS_PDE
#define ENABLE_ATO_LOGGING
#define ENABLE_EXCEED_FLAGS
#define IOEXPANSION
#define FONT_8x8
#define FONT_8x16
#define FONT_12x16
#define NUMBERS_8x8
#define NUMBERS_8x16
#define NUMBERS_12x16
#define NUMBERS_16x16
#define CUSTOM_VARIABLES
#include <avr/pgmspace.h>
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long buzzerinterval = 1000; // interval at which to sound buzzer (milliseconds)
long previousMillis = 0;
prog_char menu7_label[] PROGMEM = "Version";
prog_char menu8_label[] PROGMEM = "Turn ON/OFF Skimmer";
prog_char menu9_label[] PROGMEM = "Turn Off Skimmer";
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
void MenuEntry8()
ReefAngel.Relay.Toggle(Box1_Port8);
ReefAngel.Relay.Write();
void MenuEntry9()
ReefAngel.Relay.Off(Box1_Port8);
// draw main relay
#ifdef RelayExp
// draw 1st expansion relay
#endif // RelayExp
// Change the 45 to adjust the horizontal position of the text
void CheckReservoirStatus(byte channel, byte pump)
if ( ReefAngel.IO.GetChannel(channel) )
// If empty, shutoff the port, trigger alert
ReefAngel.CustomVar[channel] = 1;
ReefAngel.Relay.Off(pump);
// If not empty, turn on the port, clear alert
ReefAngel.CustomVar[channel] = 0;
ReefAngel.Relay.On(pump);
void MyCustomATO(int ATOTimeout)
This function works as follows:
When it's time to topoff the system, we check the levels of each
of the three reservoirs. If a reservoir is empty, we set a custom
flag to indicate it's empty on the portal and we do not start that
pump. Otherwise, we clear the custom flag for the reservoir and
start the pump.
The function monitors the switch levels like normal.
Monitor the status of the reservoirs while topping off.
When the high switch is triggered (aka, finished topping off),
ALL ports are turned off regardless of status (doesn't hurt to do this).
If the timeout occurs, the LED light comes on and all ports are
turned off just like when we finish topping off.
unsigned long TempTimeout = ATOTimeout;
TempTimeout *= 1000;
if ( ReefAngel.LowATO.IsActive() && ( !ReefAngel.LowATO.IsTopping()) )
ReefAngel.LowATO.Timer = millis();
ReefAngel.LowATO.StartTopping();
// Check the level of each reservoir
// If empty, set the alert and don't start topping off
// otherwise if not empty, clear the alert and start topping
CheckReservoirStatus(0, Port5);
CheckReservoirStatus(1, Port6);
CheckReservoirStatus(2, Box1_Port5);
// Monitor levels while topping off, to prevent a reservoir from running dry
// Might need to remove this check here -- Nope, this seems to work fine.
if ( ReefAngel.LowATO.IsTopping() )
if ( ReefAngel.HighATO.IsActive() )
ReefAngel.LowATO.StopTopping(); // stop the low ato timer
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.Off(Box1_Port5);
if ( (millis()-ReefAngel.LowATO.Timer > TempTimeout) && ReefAngel.LowATO.IsTopping() )
ReefAngel.LED.On();
#ifdef ENABLE_EXCEED_FLAGS
InternalMemory.write(ATO_Exceed_Flag, 1);
#endif // ENABLE_EXCEED_FLAGS
#ifdef ENABLE_ATO_LOGGING
// bump the counter if a timeout occurs
AtoEventCount++;
if ( AtoEventCount >= MAX_ATO_LOG_EVENTS ) { AtoEventCount = 0; }
#endif // ENABLE_ATO_LOGGING
// Initialize the custom menu
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Box1_Port3);
ReefAngel.OverheatProbe = T1_PROBE; // Use Temperature probe 1 to check for overheat
ReefAngel.StandardLights(Port1,23,0,2,0); // Moon lights on 23:00-02:00
ReefAngel.StandardHeater(Port2,780,790); // 800w heater on at 78.0, off at 79.0
ReefAngel.MHLights(Port4); // MH on 14:00-22:00, delay 15m if power fails
ReefAngel.StandardLights(Port7,21,0,13,0); // Sump lights on 21:00-13:00
ReefAngel.StandardLights(Port8,8,0,21,0); //Plant lights on 08:00-21:00
ReefAngel.MHLights(Box1_Port1); // MH on 14:00-22:00, delay 15m if power fails
ReefAngel.StandardHeater(Box1_Port2); // 250w heater on at 78.5, off at 79.0
ReefAngel.StandardLights(Box1_Port4); // Actinics on 13:00-23:00
//ATO function
MyCustomATO(InternalMemory.ATOTimeout_read());
//Notify when sump level is low
if ( ReefAngel.IO.GetChannel(4) )
ReefAngel.CustomVar[4]=1;
// If the sump level is about to cavitate the pumps, then sound the alarm
if(currentMillis - previousMillis > buzzerinterval) {
// save the last time the buzzer turned on
previousMillis = currentMillis;
// if the buzzer is off turn it on and vice-versa:
if (ReefAngel.PWM.GetDaylightValue() == 0)
ReefAngel.PWM.SetDaylight(25);
ReefAngel.PWM.SetDaylight(0);
// Turn the buzzer off when the sump level is above cavitation levels
ReefAngel.CustomVar[4]=0;
//If the ATO float switch is stuck, and the topoff pump timeout flag is set, then set C5=1
ReefAngel.CustomVar[5]=InternalMemory.read(ATO_Exceed_Flag); //Note that this value should be either 0 or 1, but for some reason is 254 or 255.
//Vodka dosing
if ( ReefAngel.IO.GetChannel(3) ) //Check there is vodka in the reservoir
ReefAngel.Relay.Off(Box1_Port6); //If no vodka, then set a variable and turn off the port
ReefAngel.CustomVar[3]=1;
else //If there is vodka, then dose
ReefAngel.CustomVar[3]=0;
ReefAngel.DosingPumpRepeat1(Box1_Port6);
//Monitor the water level in the display
ReefAngel.CustomVar[6]=ReefAngel.IO.GetChannel(5);
ReefAngel.Portal("btorrenga");
Here is /r99 after pulling power on each relay:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<RA>
<T1>800</T1>
<T2>800</T2>
<T3>743</T3>
<PH>811</PH>
<R>68</R>
<RON>0</RON>
<ROFF>79</ROFF>
<R1>204</R1>
<RON1>0</RON1>
<ROFF1>123</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>1</ATOLOW>
<ATOHIGH>1</ATOHIGH>
<EM>32</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<IO>0</IO>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>190</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
Entering feeding mode did not work properly, since expansion port 8 turned off but expansion port 3 did not:
<RA>
<T1>798</T1>
<T2>798</T2>
<T3>743</T3>
<PH>811</PH>
<R>68</R>
<RON>0</RON>
<ROFF>79</ROFF>
<R1>204</R1>
<RON1>0</RON1>
<ROFF1>123</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>1</ATOLOW>
<EM>32</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<IO>0</IO>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>190</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
Upon feeding mode timeout both expansion ports 3 and 8 properly turned on:
<RA>
<T1>798</T1>
<T2>800</T2>
<T3>741</T3>
<PH>810</PH>
<R>68</R>
<RON>0</RON>
<ROFF>255</ROFF>
<R1>204</R1>
<RON1>0</RON1>
<ROFF1>255</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>1</ATOLOW>
<EM>32</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<IO>0</IO>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>190</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
