WiFi Help
Re: WiFi Help
Just tried to reload the WifiTestCode and it gets hung up. Keep getting failed to send command and time out errors.
Re: WiFi Help
Here is the setup message I have been getting. This is after a factory restore.
* Please, select a serial port and click the "Connect" button
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM4
> set u b 57600
> set s p 0
> save
> reboot
Removing connection to COM4
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM4
< CMD
< ls
< FL# SIZ FLAGS
< 2 20 3 WiFly_GSX-2.32
> ls
< 22 11 3 wps_app
< 33 1 10 config
< 34 20 3 WiFly_GSX-2.32
< 54 11 3 wps_app
< 65 1 10 user
< 190 Free, Boot=34, Backup=2
< <2.32>
< load user
< AOK
> load user
< <2.32>
< save
< Storing in config
> save
< <2.32>
< save
< Storing in config
> save
< <2.32>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <2.32>
> set w s dd-wrt
< set w s dd-wrt
< AOK
< <2.32>
> set w p
< set w p
< AOK
< <2.32>
< set w k 00000000000000000000000000
< AOK
< <2.32>
< save
< Storing in config
> save
< <2.32>
> reboot
< reboot
< CMD
< show n
< SSid=dd-wrt
< Chan=1
> show n
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <2.32>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=10.1.10.101:2000
< NM=255.255.255.0
< GW=10.1.10.1
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <2.32>
> reboot
< reboot
Found router router
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 22 11 3 wps_app
< 33 1 10 config
< 54 11 3 wps_app
< 65 1 10 user
< <2.32>
< load user
< AOK
< <2.32>
> load user
< save
> save
< Storing in config
< <2.32>
> save
< save
< Storing in config
< <2.32>
< AOK
< <2.32>
< set w s dd-wrt
> set w s dd-wrt
< AOK
< <2.32>
> set w p
< set w p
< AOK
< <2.32>
< AOK
< <2.32>
< save
< Storing in config
> save
< <2.32>
< reboot
> reboot
< CMD
< show n
< SSid=dd-wrt
< Chan=6
> show n
< Assoc=FAIL
< Rate=0, 1 Mb
< Auth=OK
< Mode=WPA2
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <2.32>
< get i
< IF=DOWN
> get i
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <2.32>
> reboot
< reboot
Found router router
Port 2000 is now being forwarded to 0.0.0.0
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
< ls
< FL# SIZ FLAGS
> ls
< 22 11 3 wps_app
< 33 1 10 config
< 54 11 3 wps_app
< 65 1 10 user
< <2.32>
< load user
< AOK
> load user
< <2.32>
< save
< Storing in config
> save
< <2.32>
< save
< Storing in config
> save
< <2.32>
< AOK
< <2.32>
> set w s dd-wrt
< set w s dd-wrt
< AOK
< <2.32>
> set w p
< set w p
< AOK
< <2.32>
< AOK
< <2.32>
< save
< Storing in config
> save
< <2.32>
> reboot
< reboot
< CMD
< show n
< SSid=dd-wrt
< Chan=1
> show n
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <2.32>
> get i
< get i
< IF=DOWN
< DHCP=ON
< NM=255.255.255.0
< GW=10.1.10.1
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <2.32>
> reboot
< reboot
Found router router
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 22 11 3 wps_app
< 33 1 10 config
< 54 11 3 wps_app
< 65 1 10 user
< <2.32>
< load user
< AOK
< <2.32>
> load user
< save
> save
< Storing in config
< <2.32>
> save
< save
< Storing in config
< <2.32>
< AOK
< <2.32>
< set w s dd-wrt
> set w s dd-wrt
< AOK
< <2.32>
> set w p
< set w p
< AOK
< <2.32>
< AOK
< <2.32>
< save
< Storing in config
> save
< <2.32>
< reboot
> reboot
< CMD
< show n
< SSid=dd-wrt
< Chan=6
> show n
< Assoc=FAIL
< Rate=0, 1 Mb
< Auth=OK
< Mode=WPA2
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <2.32>
< get i
< IF=DOWN
> get i
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <2.32>
> reboot
< reboot
Found router router
Re: WiFi Help
< Assoc=FAIL
< Rate=0, 1 Mb
< Auth=OK
< Mode=WPA2
< DHCP=FAIL
That means it is not associating and not getting an ip from the router.
The SSID and passphase are case sensitive. Make sure that you type it just like it is setup in the router.
< Rate=0, 1 Mb
< Auth=OK
< Mode=WPA2
< DHCP=FAIL
