My main tank is in my kitchen and my sump/fuge/etc are in the basement. I bought a second relay box to run things in the basement.
So my question is: can I use a generic USB extension cable to extend the cable that "seems" to be USB to mini-USB? I just want to make sure the pin-out is the same, etc. and that I do not fry anything. :^)
Thanks! Every thing else is working great.
Cheers,
Gordon
Type of cable for additional relay box - true USB?
Re: Type of cable for additional relay box - true USB?
Yes, cable is USB. Make sure you get a good quality shielded cable if you are extending it or you may experience interferences coming from noise that gets absorbed in the long run.
Will do, thanks Roberto!
Cheers,
Gordon
Cheers,
Gordon
