Help!!! No internal memory found and uploading error
Junseld
Re: Help!!! No internal memory found and uploading error
Post by Junseld »
I am having the same issue and I also notice that the "base system device" driver did not install correctly.
Junseld
Post by Junseld »
This is the code I am trying to upload:
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.DayLights( Port1 );
ReefAngel.StandardHeater( Port2 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.Wavemaker1( Port6 );
ReefAngel.StandardFan( Port7 );
ReefAngel.MoonLights( Port8 );
Junseld
Post by Junseld »
This is the error I get with trying to upload the initial internal memory:
Copyright (c) 2000-2005 Brian Dean,bdmicro/
Using Port : \\.\COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude done. Thank you.
