Help!!! No internal memory found and uploading error
Re: Help!!! No internal memory found and uploading error
I uninstall the software and reinstall it still not working. I even used another computer and I still have same problem.
I use the second generation of RA, I bought it new in the box from another person who had never used. I use it since February 2012 with success.
Thank
Thank
Osaka 40g with 55g sump
Radion, 2X Tunze 6045, Swc-160 mini cone
So, you are positive it is a standard RA and not RA+, correct?
Double check the cable connection.
If you still can't get it to work, PM for RMA#.
what is the difference for the cable connection between the RA and RA+ ?
I'll check (but I'm sure it is a standard RA)
There is no difference in connection, but you have to change the board on Arduino.
On menu Tools->board.
I tried different connection, RA +, RA and RA with optiboot and nothing works. I really have no idea why nothing works. I'll keep trying, do you think a bad instalation jumper may have caused this problem?
Here is a picture how I had installed the jumper and the unit message
Yes, it is wrong.
You need to have the jumper placed on the left most pins, connecting the two pins.
Ok, this is how I set the jumper when the error began.
Thereafter I handed the jumper to the normal position and I make all test, did not work.
Having put a jumper in the wrong position, can i have damage the RA ?
No, it won't damage.
The normal position is on the far left most pins.
Oh man...
I feel really stupid
I believed that the jumper normal position is on the far right most pins. I gave it a good position and everything works fine.
Sorry for this stupid mistake.
Thank you very much for your support Roberto, there is no controller that is after sales service as effective as ReefAngel.
Thank you so much this is very appreciated.
I am having the same issue and I also notice that the "base system device" driver did not install correctly.
This is the code I am trying to upload:
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.DayLights( Port1 );
ReefAngel.StandardHeater( Port2 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.Wavemaker1( Port6 );
ReefAngel.StandardFan( Port7 );
ReefAngel.MoonLights( Port8 );
This is the error I get with trying to upload the initial internal memory:
Copyright (c) 2000-2005 Brian Dean,bdmicro/
Using Port : \\.\COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude done. Thank you.
avrdude: Recv:
